Just barely failed emissions(dammit)
Discussion in 'The Injection Section' started by 88-383, Jul 3, 2006.
  1. 88-383
    88-383 1/2 ton status
    Sep 11, 2005
    142
    Tracy. CA
    My HC's moved just outside passing when the truck shifted gears and went into 3rd during the loaded dyno emission test at 25mph. I'm wondering whats the easiest way to get a pass? Should I try and lean it a little more in 3rd w/light load? Play with timming? Fuel pressure?
    Kelvin
    http://www.jaybquick.com/_Kelvin_Upload/Smog Test-1.tif
    Setup:355,10.1,CNC TF 195's,Ported Edelbrock manifold,46mmT-body,75#inj's,219@.050 .520 HR etc....
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you could pull a little timing and maby a little fuel
  3. 88-383
    Sep 11, 2005
    142
    Tracy. CA
    Yup, I think another chip will have to be burnt:doah:
    KM
  4. Creek
    Creek Registered Member
    Mar 17, 2006
    36
    Mint Hill, NC
    You might want to look at the Accel. Enrichment Vs. Differential MAP table. Also be aware that once the mixture gets too lean it can cause hydrocarbons to be high because the flame front can't sustain its self across the chamber. This is more predominate during high cylinder pressures (higher MAP) such as occurs when the RPM drops under load. Also look at your knock counts at that time as detonation can cause an incomplete burn.
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    A new cat will cure it. :thumb:
  6. 88-383
    Sep 11, 2005
    142
    Tracy. CA
    I wish, it has a brand new factory cat with about 30mi on it. I'll post back after I get it sorted out.
    km
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Well, was the vehicle nice and hot when you had them smog it, if not that will make a difference.
  8. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    Or jam it in 4wd, here in texas they usually dont dyno 4wd, just neutral and smog test... If that.
