Just bought a Detroit lkr, need torque specs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Liberator, Aug 30, 2001.
  1. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    I just got my Detroit locker in the mail today. I'll be installing it into my 14 bolt FF this weekend but can't seem to find bolt torque specs. I need the proper bolt torque specs for the carrier bearing caps and the carrier bolts themselves! Can anybody help?
    Bo
    If it breaks, it wasn't good enough!
  2. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    my book says 135 ft/lbs-- i know taking the off was fun
    Hut in the well is goin on in here?
    sun desert offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
  3. K5RON
    K5RON 1/2 ton status
    Apr 14, 2001
    219
    120 on the ring gear and 135 on the bearing caps
    Ron
  4. Liberator
    Jul 16, 2001
    276
    Thanks, is that spec just for the bearing caps? Do you have specs for the carrier housing bolts?
    Bo
  5. Liberator
    Jul 16, 2001
    276
    with the 14 FF I won't have to take off the ring gear. The carrier is a 2-piece carrier andthe locker just fits right inside!
  6. ScoobyDann
    Mar 9, 2001
    305
    ok, im learning as much as you at the moment, but my book dosn't say any specs for the carrier housing bolts.
  7. K5RON
    Apr 14, 2001
    219
    Ring gear bolts and carrier housing bolts are one in the same. The ring gear bolts also hold the carrier housing together.
    Ron
  8. ScoobyDann
    Mar 9, 2001
    305
    "i see" said the blind man
  9. Liberator
    Jul 16, 2001
    276
    Thanks for the info.
    Bo
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    You will have to take the ring gear off to get the 2 piece carrier separated in order to remove the old spider gears and install the Detroit Locker.
    The ring gear is what holds the carrier halves together by those bolts on the backside of the ring gear.
    <font color=blue>"Ya don't have to beat it, ya know!!!</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
