Just Bought a Diesel
Discussion in '1982-Present GM Diesel' started by DOCKAWI650, May 1, 2003.
  1. DOCKAWI650
    DOCKAWI650 Registered Member
    Sep 29, 2002
    61
    Gboro, NC
    I just bought a diesel K5 blazer. 1982 with 58000 on rebuild, 35" super swampers TSL, lockers front and rear and power windows cd player and A/C all for only $1100. What do you guyes think...the only think I dont like is the 10 bolt rear. I will be looking into a 14 bolt very soon.
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Congratulations! Watch out if you have the 700r4 and stock drive train turning those bigger tires.
  3. Jaguargt
    Jaguargt Registered Member
    Mar 14, 2003
    46
    Guatemala
    what could be damaged, if he is running stock gear and a 700R4, with 35's?, and help me, why is better a 14 bolt rear end than a 10 bolt? thanx for the ilumination.
  4. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    [/ QUOTE ] Its bigger in every way, the larger tires put more strain on the driveline. Some people have problems some dont.
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Depends on how hard you wheel it, some people can survive with 37's on 1/2 ton gear, but once you start having fun with it(especially rockcrawlin') you can break 1/2 ton stuff like a toothpick...
  6. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    Factor in the amount of torque produced at very low rpm's and snapping a 10 bolt would be easy with 35's...
    Rene
  7. Jaguargt
    Mar 14, 2003
    46
    Guatemala
    thanx for the info. i have a 85 6.2, and i'm thinking in buy a 7-10" susp lift to install 35's or 37's, i'll need to swap to a 14 bolt?, from what trucks can i take one? thanx.
  8. JORGE
    JORGE 1/2 ton status
    Jan 10, 2001
    213
    VITORIA-GAZTEIZ(ALAVA)BASQUE COUNTRY,SPAIN
    14 bolts? I was thinking to go to 12 bolts ...
    The 14 bolts is not the 8 lugs axles ?(I,m also lost in the axles&gears subject...)
  9. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    yes the 14bff is an 8 lug axle, and you can find them under 1 ton trucks as well as some 3/4 tons as well. /forums/images/graemlins/pimp1.gif
  10. JORGE
    Jan 10, 2001
    213
    And the 12 bolts?Is not enough stronger for hard wheeling and not go to 8 lugs?
    Thanks.
  11. azblazor
    May 5, 2001
    1,953
    My concern is more with running 35" tires with the 700R4 with the original axle ratio, but if he has added lockers he has probably lowered the ratio. I think a stock 700R4 overheats with stock gears ( 3.08, 3.43 maybe even 3.73) and 35" tires.
  12. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    Mine does fine with stock running gear. Although I rarely put it in overdrive.
