Just bougth a 1984 Chevy Suburban - I need suspension help
Discussion in 'The Garage' started by spitdirtcom, Jun 11, 2004.
  1. spitdirtcom
    spitdirtcom Registered Member
    Jun 11, 2004
    8
    Hello,
    I just purchased a 1984 Chevy suburaban 3/4 ton with a small block. I am looking into lifting it 4". What lifts do you suggest. I just want front springs and rear blocks. It already has the dual shock kit on it (see attached) I was reading the installation instructions for the TC kit. It states that if you are running the dual shock kit, the auxilary shock extended lenght should be 26". Is that correct and how do I know which is the auxilary shock? I am thinking about running the Bilstein 5100 shocks. Are TC shocks any good.
    This is my wifes daily driver so it will mostly be just driven around town hauling the kids. Any help will be greatly appreciated.
    Kory
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Tuff Country or BDS. I'm not a fan of blocks. I'd say ORD's 4" Shackle flip for the rear. Yeah the blocks are cheaper and easier, but I still like the ORD flip better.
  3. spitdirtcom
    Jun 11, 2004
    8
    Can I use the stock springs in the rear if I go with the 4" shackle flip. What kind of ride can I expect?
    Kory
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    do you have any more pics of it? if those are stock springs on it they would be alot closer to the bumpstop by now. also the aux. shock they are talking about is the ones in the stock set up. where one is longer then the other. the kit you have just uses 4 of the same shocks.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Stock springs work well with rear flip. Ride is a little softer than stock. If your springs are good it sits just right. /forums/images/graemlins/k5.gif
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Check out this link:
    'burb buildup
    I did the writeup on this so that guys like you could check it out and know what it looks like and have an idea of how it works.
    Hope this helps!
  7. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Are you thinking that it is stock height now? Is that a pic of your sub, or did you just link to it? It is hard to tell by the pics, but if that is the leaf spring that extends out to the left of the bottom of the headers, I would guess that it is already lifted.
  8. spitdirtcom
    Jun 11, 2004
    8
    MY suburban sits at stock height right now. The pick is just a random pick I posted to show the dual shock setup that came on it. So if I go with the 4" ez ride springs in the front I will just need four 23" fully extended length shocks right? Will blocks be OK in the rear with 30" fully extended shocks? The lift is mainly for looks, it will hardly be driven off road, just to get me to campsites.
    Thank you for all your guys help.
    Kory
  9. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I have a 4" on mine, I like the look of it.
    Blocks will be fine in the rear. Not sur eon the measurements of the shocks when I did my 4" lift I just got everthing as a kit.
  10. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Just call ORD 970-945-7777 and they can help you with TC EZ Rides for the front and a block or shackle flip for the rear. They can help you with shock length as well. I ran the TC shocks until I went long travel up front and they worked fine but a Bilstein is gonna ride better. You probably dont want four stiff shocks up front unless you like a firm ride. /forums/images/graemlins/thumb.gif
  11. ugly_blazer
    Apr 12, 2004
    1,214
    I agree with bigyellowjimmy, I think that dual shocks are too much for the front and will be too stiff. I run a 4" block and add-a-leaf on the rear of my K20 and don't have any problems. It never sees any hardcore wheelin', just a little mud every now and then. Get a price on a whole kit that has front springs, rear blocks, 4 new shocks (2 front and 2 rear), new u-bolts, and a raised steering arm. That should work good for your needs and be the cheapest way to go.
  12. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I can just barely see part of the spring pack in the pics, but they don't look like they're stock. Your springs have the ends curved upwards, like a smile. The ends of the stock springs actually curve downward, like a frown. Your springs also have at least 4 leaves. The stock springs only had 3 leaves max.
    Looks to me like you already have at least a 2.5 inch lift and an aftermarket dual shock set. /forums/images/graemlins/cool.gif
    What does the back look like? Does it have any blocks installed between the springs and axles?
  13. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    Evidently the photo isnt of his truck...
  14. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We can get you a spring front/block rear kit, no problem. For your intended use it will probably be fine.
    The TCI shock lengths work pretty well for the 4" lift so you shouldn't have any worries there.
