just checking interest dana 60 high pinion rear
Discussion in 'Suspension | Axle' started by virgilh, Apr 3, 2006.
  1. virgilh
    virgilh 1/2 ton status
    Sep 8, 2004
    Sacramento California
    I have a dana 60 rear axle for a chevy pickup 1973-87 or blazer suburban ext. it is a high pinion housing (was a ford front axle) cut to fit the rear it has set 20 bering ends with the stock chevy 6 lug brake bolt pattern so you could bolt on your stock 6 lug brakes. i have a set of 5.38 gears with a 35 spline powerlock for it with a dana master kit. i havent ordered the axles from dutchman yet but if someone needs it i could buy the axles and completely assemble it with out the brakes on it, but i will have the brake backing plates on it. pm me if someone is interested. I think its worth 1500 in pieces or 2200 assembled let me know
