Just did a tune up.
Discussion in 'The Garage' started by hawkeye649, May 24, 2006.
  1. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    :doah:
    1990 GMC F/S Jimmy
    350TBI HEI/700R4
    Changed: Rotor, cap, wires, plugs. (all new) Coil: Off of parts suburban.(Believed to be relatively new)
    Drew a diagram of the plugs and order as I took it apart-so I'm pretty sure the wires are in order. Haven't checked against my manuals though, yet.
    All connections seem to be secure.
    I pulled the valve covers off when I was in there just to paint them, so I had to disconnect some "stuff" but I can't find anything I forgot to re-connect.
    The gasket for the PCV valve was toast, and died when I was taking it out. Right now the tube for the PCV is plugged, but the PCV hole in the valve cover is still open. IIRC an improperly operating PCV valve can cause rough operation.
    So why is my truck running like poo-poo? :mad:
    First time I took it out the truck just seemed a tag sluggish and the shifts weren't correct. Since I had accidentially moved the rotor a bit when working on it, I played with the timing a bit to get it running better. All I managed to do was get it running worse, and I can't find the wires to my timing light...
    Any suggestions as to where to look? I don't think it's a firing order issue, it runs too well for that.. but it doesn't sound as good as before the tune up and it doesn't work right of course... Think it could be timing? :(
  2. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,025
    850
    Pinckney, MI
    EGR valve, EGR solonoid??? but I would also check for a vacuum leak.
  3. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    I'll take a peek at EGR valve function.... may have disconnected something whiel I was working on it. It was running at 5 Hg before I connected the PCV by using an almost equally junk gasket from my burb. Now it's up to 15hg and fluctuating about 4 hg very fast. My boogs say to suspect valve guide problems but I don't think that's my case, it was running fairly smooth till about 3 days ago when I stabbed it and got 1 fart out of it and had to re-stab, so I decided it was tune-up time....
  4. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    WAY retarded timing... limped over to my friends motorcycle shot and set it and it flew on home. It's idleing very high and that's what threw off the "by ear" timing. Hopefully once the reset ECM learns it's self again it will run lower, or I need to figure out what's causing the high-idle....
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
