just finished by instrument bezel...
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by harry, Jun 27, 2002.
  1. harry
    harry 1/2 ton status
    Feb 9, 2001
    106
    san diego, CA
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    looks awesome very nice job /forums/images/icons/smile.gif
  3. ChrisM72beast
    ChrisM72beast 1/2 ton status
    May 29, 2001
    214
    Granada Hills CA.
    That cluster is bad azz /forums/images/icons/laugh.gif
    Chris M
  4. Supergas
    Supergas 1/2 ton status
    Oct 17, 2001
    161
    Texas Coast
    Harry:
    Looks killer.. would you mind posting the details on the bezel, where you got it?? and the gauge part numbers??
    Thanks,
    SG /forums/images/icons/cool.gif
  5. harry
    Feb 9, 2001
    106
    san diego, CA
    thanks
    My cousion made it using auto-cad and then ran the program on the Hass. I am vary happy with the way it turned out.
  6. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    is this the same one you were asking opinions on last week?if it was did you fab it yourself or have it made.looks very high quality.nicccce
  7. harry
    Feb 9, 2001
    106
    san diego, CA
    thanks,
    Robin was asking on opions...
    I used auto-meter "ULTRA_LITE"
    http://autometer.com/hp/index.html
    I used the stock plastic peice and just took all the extra plastic material away with a dremel.
    My cousion has a machine shop and made the peice that holds the gauges. he saved the program and I think it could be duplicated for fairly cheap. palcement and size of the holes were the easy part.
  8. That is outstanding! What did the whole setup cost you in parts?
  9. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    Harry,
    Looks great! I had a question about the speedo. It appears to be electronic rather than mechanical. How will it be connected? Thx. JT
  10. harry
    Feb 9, 2001
    106
    san diego, CA
    The gauges set me back about $550 /forums/images/icons/shocked.gif /forums/images/icons/shocked.gif
    the aluminum face plate just cost me time.
    The electric spedo has a waterproof sending units that fits in the stock location on the transfer cast. the two connect with a piece of 12 gauge wire.
  11. Robin
    Robin 1/2 ton status
    Oct 30, 2001
    184
    Georgetown, Texas
    Good job man.
    See guys, I'm not the only one who likes a clock on the dash...
    BTW: What do your LED's light up for?
    On the electric speedo, does on sending unit fit all driveline ratios? Is it infinitely tunable? How do you calibrate it for your application?
  12. 1 FN HI K5
    1 FN HI K5 1/2 ton status
    Aug 7, 2001
    465
    Northern CA Out in the stick\'s
    That look's alot like my dash. I went with Auto meter Phantom Guages. Nice Job You can see pic's of my dash clicky below. Im going to get rid of the clock and go with a tranny temp guage.Later <font color="red">1 FN HI K5 </font color>
  13. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Don't you need a tranny crack gauge more, Brad?
  14. Robin
    Oct 30, 2001
    184
    Georgetown, Texas
    BTW: I looked at your crack (it's butt ugly)... /forums/images/icons/blush.gif I've never heard of a 350 cracking here or that this is a weak spot. Was there any loose bolts on the mount or transfer case that would have stressed the case here, or did something internally break that caused the case to crack?
  15. 1 FN HI K5
    Aug 7, 2001
    465
    I dont think anything internally broke. I hope, anyway the guy that rebuilt my tranny say's he is 99.9% sure that the tranny cracked is because i didn't have the "L" bracket installed on my transfer case to the frame. I guess they put it there for a reason. <font color="red"> 1 FN HI K5</font color>
  16. Robin
    Oct 30, 2001
    184
    Georgetown, Texas
    So the transfer case was hanging off the transmission mount only?
  17. 1 FN HI K5
    Aug 7, 2001
    465
    Yep /forums/images/icons/frown.gif <font color="red"> 1 FN HI K5 </font color>
  18. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The t-case cross member was there...just not the direct frame to t-case mount.
