Just finshed my tranny install now "Check engine" light comes on. Help...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Jan 7, 2001.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    Just finshed my tranny install now \"Check engine\" light comes on. Help...
    I just put a brand new 700r in my 1990 rig. Everything is stock. Now my check engine light comes on and "I think" my idle drops and becomes slightly rough when it does. If I turn the engine off and restart the light turns off and everything is ok for a while. I also put a tach in. Where do I begin? any ideas? Thanks.
  2. 82K5
    82K5 1/2 ton status
    191
    kansas city
    Re: Just finshed my tranny install now \"Check engine\" light comes on. Help...
    check all your fluid levels, including oil.
    Phil from K.C.
    1982 K5 Blazer Silverado
    Built in Flint, Michigan-January 1982
    It has one of the very first 700R4 transmissions ever built.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    make sure no wires are pinched in between the bellhousing and the block also make sure that when you put the tranny in you did not damage the oxygen sensor wires.
    s.smith 77blazer lookin 4 mud
  4. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I think you bumped your oxygen sensor. It is in that general area and could have got damaged during the change. My old man's Jimmy did the same check engine routine and he had it fixed and it works fine.
    K5:Big, slow, and flys through snow. [​IMG]
  5. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    why dont you check for which code is showing .
    88k5 silverado w4"lift soon to have <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
  6. shum1
    Oct 8, 2000
    270
    UTAH
    So I ran the error codes and it came up #42 electronic spark timing. When I installed the tach, I connected it to the free end of a white wire comming off the coil. Was this the correct wire? The tach works but mabey I messed somthing up. Thanks
  7. Blazer_Boy
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    That is the factory wire for a tach. All I can say is disconnect it and see if it was it. I think some of the older wired were brown but for the majority of years its been white.
  8. coopertwpk
    Mar 18, 2000
    478
    The wire should be green not white, Ill check again tomorow but the white is a timing disconnect to set the timing it runs towards the wire junction and plugs into a wire the same color.
  9. shum1
    Oct 8, 2000
    270
    UTAH
    So if my timing disconect was disconected, where exactly does it connect?
