Just fired 355 for first time..........
Discussion in 'The Garage' started by dirtwarrior17, Jan 2, 2005.
  1. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    Ok I just fired the beast 5 min ago. It idles real rough and i know it's missing cause i don't have a timing light yet but i have to give it throttle to keep it runnin. Could 02 sensor and vaccuum lines be part of the problem? im still waitin on wire for my o2 sensor so i ran it without the o2 sensor. I tweaked the timing and it got better but not timed. could somebody tell me if an 02 sensor will affect how it runs, i know it will but not how much.. or if the o2 sensor has more affect on a high hp motor. It idles real rough and i know it's missing cause i don't have a timing light yet but i have to give it throttle to keep it runnin.
    Also i looked in the manual and couldn't find out wut other sensor is not hooked up. It sits on the back of the intake manifold and has a 2 prong plug. Manual says it is a coolant temp sensor but i got one in the front. Is there 2 coolant temp sensors on an 88 k5?
    I will have pics in couple weaks and maybe a soundbyte.
    Oh yeah y can't i post anywhere else besides garage?
    Says i need to have somebody activate account? How?
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    oil pressure sensor? :confused:
  3. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    no.... close but no. oil pressure sensor is to the right of the distributor. this one sits in the manifold and is on the left rear corner if you are looking at it from the front.
  4. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    Also have 2 left over vacuum lines, one because the vavle covers have a breather instead of a crankshaft valve and i don't know what the last one does manual doesn't say. Tbi is a holley 670 cfm with 89 pph injectors.
    Egr vaccuum, egr main, and canister vacuum are hooked up... whats else is left?
  5. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    That crankshaft valve has me stumped:rotfl:
  6. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    think its a pcv valve. dunno i don't have my manual on me. on a stock tbi itd go from the valve cover to the tbi......
    So does the o2 have alot to do with how smooth a motor runs that or is it the vacuum lines?
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    O2 doesnt have an effect till the motor warms up. I 4get the exact temp, but until then the O2 sensor wont affect it.
  8. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    I just looked it up... 600 degrees f. Must be all timing.
