Just got a 77 K5 Blazer for $204.52!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scout62, Apr 27, 2003.
  1. scout62
    scout62 Newbie
    Apr 27, 2003
    I won this truck on ebay! Anyhow seller says it's a 350 but vin says it should be a 400, anyway to tell aside from casting #s? Can someone tell me what emissions gear this truck should have and what the vapor canister looks like? Body is kinda rusty and the interior is ok and it runs good. The tranny sat dry for 2 years so it's shot now but I'm hoping to have it rolling by the sencond week of june when I'm going camping. /forums/images/graemlins/k5.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Man! you cant beat that. /forums/images/graemlins/cool.gif
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Welcome to CK5. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif If it's the original motor, more then likely it is a 400 and the owner didn't know the difference.
  4. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    77 is the year! ok, well I own that year so I'm partial. The smog stuff on a 77 is pcv valve, heat riser and all
    your vacuum hoses in order. No cat needed on this year.
    Most likely it's a 350. Trucks this old have been through a few owners most likely.
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    [/ QUOTE ] actully you can. my dad bought a 78 k5 for $76 bucks and we actually drove it around yesterday /forums/images/graemlins/ears.gif
    if you want to take the alternator off. there is a little pad on the passenger side infront of the head with a bunch of numbers stamped on it (you probably will have to scrape it off). there should be two sets. i think the first one has 2 or 3 letters at the end of it. take these letters and click here and select the correct page from the pull down and find it on the page and it will tell you what size, year, and sometimes what model it cam out of.
  6. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    nice. I got my 79 K5 for 200$ all the body panels were replaced including doors and tailgate and glassbut the floor was typically rotted in the usual place. floor support under the driver side floor was rotted away. no motor but the tranny was supposedly rebuilt with a shift kit. Bed floor is rotted and needs replaced. Instead of installing body bushings they used the flat square pieces of rubber used for pickup beds. and it needs a hood, call me a sucker but I wanted a project and something to put my 325hp 350sb that I salvaged from my chevelle into.
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] I've got a 76 K5 with the original motor and it's a 400cid sbc
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Yeah, My brother in law bought a '79 with new tires and a good motor for $200. Body is in good condition also. It has sat next to his house now for two years and not moved. I have tried to buy it many times. /forums/images/graemlins/tongue.gif
  9. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    that blazer is a good candidate for a camo paint job /forums/images/graemlins/grin.gif
    if you would have bought both of them he had, you could have combined them to use the best of both /forums/images/graemlins/thumb.gif
  10. ratchetmaster
    ratchetmaster Registered Member
    Mar 26, 2003
    47
    PLEASANT GROVE, UTAH U.S.A.
    harmonic balancer is how you can tell easily if it is a 400 or a 350. You can also tell by the flex plate if the inspection plate is off.
    400s are externally balanced . . . the flex plate has a weight welded to it.
    Also, the Balancer has a big "cutout" on the back side which is about 1/3 the total size of the balancer.
    so rather than a continuous round shape that is about 1 1/2 inches in depth, it is missing the back side of about one third of it so that it is only about 1/2 in wide on part of it.
  11. scout62
    scout62 Newbie
    Apr 27, 2003
    so it's notched on the back side at some point? /forums/images/graemlins/ears.gif
