Just got my 14bff, have ???'s about e-brake(NOT NORMAL)
Discussion in 'The Garage' started by 85mudblazin, Aug 12, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Just got my 14bff, have ???\'s about e-brake(NOT NORMAL)
    I just my 14bff tonight and I was looking at the e-brake cables and the passenger side is about 35" from where it mounts to the drum to the end of the cable and the other is a little longer like 36" or 37" and my current 10b passenger side is way longer since it travels all the way across the axle to where it mounts at the fram and the driver's side is short, so how do I hook it up?? PLEASE HELP
    -Chris
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    Re: Just got my 14bff, have ???\'s about e-brake(NOT NORMAL)
    Going through the same problem now, from what i have gathered there are 2 options:
    1) Change backingplates and axle ebrake cables
    2) Change entire Ebrake to old style (need all retainers, brackets and cables)
    If anyone else has a suggestion, im all ears /forums/images/graemlins/ears.gif
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    CRAP your supposed to give me GOOD news jk, grrr nothin goes right these days, anyone have a easier way??
    -Chris
  4. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
  5. mechted
    Oct 19, 2003
    765
    Granbury, TX
    sounds pricey
    i've been looking for someone parting a truck, little work with a grinder and i can get everything i need, shouldnt be too expensive either
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    anyone??
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I got the new style backing plates for my 14FF from a junkyard. They had them laying on the ground under their diff rack /forums/images/graemlins/grin.gif
    How wide are your drums? For 3.5" you need to get them another 1-ton 14ff - SRW or DRW, they're the same backing plate.
    If they're only 2.5", you can get them off a 3/4-ton 14FF or the 14SF - they're the same backing plate.
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    what do the newer ones look like??
    HMM maybe ill just go disks, maybe be easier and better in the long run, hmmm how to hook up e-brake on caddy caliper??
    -Chris
  9. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    How about having a new set of Ebrake cables made? thats what I did, when I mated a ford D60 to my chev blazer, six states here did the work all they did was make one end the ford axle end and the other end they made chev blazer with an extra 12 inches added for the lift, as I remember they were about 40.00 each to have the custom ones made, and they work great! /forums/images/graemlins/waytogo.gif
  10. u2slow
    May 9, 2001
    2,217
    BC Canada
    The newer 13" backing plates look like the old ones, but theres a bump with a round hole in it - just like your old 10-bolt ones.
    Some have an extra lip around the outside that's spot welded on. (They changed the profile on the drums around '92 or so) But you can cut this off if you have any problems.
    I built by 14FF up in advance so I'd only have 1-day downtime to install it. Besides, I had less than $150 TOTAL into this axle after the backing plates. Discs would have increased the cost, and might have meant more downtime on my DD.
  11. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yea I may just do the drums for know since the disk problems havent been worked out
    thanks for the info
    -Chris
