Just got my 72, A few questions?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by mikeperez22, Jun 15, 2004.
  1. mikeperez22
    mikeperez22 Registered Member
    May 11, 2004
    41
    1. Are the front leaf springs typically so flat that they curve up instead of down or are mine just that worn out?
    2. Anybody know how to remove do-it-yourself bedliner? The previous owner did an awful job.
    3. The spring behind the front seat, I found out is to hold the jack/tire iron. Anyone have a picture to show how it all mounts together. I am missing the jack and tire iron. I plan on replacing them soon.
    4. I have two rust spots on the floorboard. There is one small one under the passenger seat area and one hole near the drivers kick panel. I'm trying to decide if I should cut the holes and patch, or replace the floor pans. Are the original floor pans in two pieces or is it two pieces welded together? What would ya'll recommend?
  2. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,959
    249
    Released from Pueblo, told I belong in Southpark
    Well only question I can answer is #1. My springs were the same way and rode like a rock so I would say very worn out. I have heard that stock they did not have much arch to them but upward arch is just bad in my opinion.
  3. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    1. On the '73+'s I know that the front springs, stock, have negative arch, and that's normal. I would guess that it's the same for you first-genners.
    2. DIY bedliner removal: I suspect you're in for some fun. I'm thinking a wirebrush wheel to get rid of the stuff that didn't bond originally, and then maybe one of the xylene cleaner/paint thinner chemicals? Either that or the gnarly jelly paint removers.
    -- A
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Maybe get someone to sand blast it.
  5. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    I know what you mean, the current owner of my 72 did a terrible job too and I want to get it out... I think blasting would be about the best way.
