Just got my fuel cell...quick question...
Discussion in 'The Garage' started by stallion85, Jun 28, 2005.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    The outer shell is only a shell right and there is a whole different tank inside? The reason I ask is because it was damaged slightly in the shipping and one of the corners is bent causing the seam on the top where the peices bolt together to seperate.
    I will post a pic if necessary.
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    What kind of cell do you get?
    There are steel or aluminum 'canned' cells with a rubber liner and there are blow molded plastic cells. With the former the 'can' is only a means to contain the bladder for mounting. With the latter what you see is the whole thing.
  3. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    It's a Jaz Pro Sport 22 Gal here is a pic........
  4. bigcountryk5
    bigcountryk5 1/2 ton status
    Mar 13, 2004
    931
    G-vegas(Greenville) South Carolina
    ouch even if it doesen't harm it which i don't know i'd send it back.....just my .02
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    If you can wate to install it, id send it back. You payed for something nice and you should get it.
  6. Grieby54
    Grieby54 1/2 ton status
    Jun 18, 2005
    782
    Houston, TX
    Definately send it back... make them pay for the shipping too
