Just gotm my Blazer today, have a question about steering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CamaroZ85, Mar 1, 2003.
  1. CamaroZ85
    CamaroZ85 Registered Member
    Feb 21, 2003
    27
    Woodbridge NJ
    There it is. Actually a mix between my 78 Blazer that I sold this guy (notice the red on the doors...that was from my 78) He mixed and matched and came up with this truck that I just bought today. The steering is loose as hell! I'm going to replace all the tierods and whatnot in a week or so, along w/ the u-joints in the front axle (I hear these can contribute to loose steering). What else should I look at? Is there a wear joint in the pitman arms of these trucks??? Are there any other issues with the steering I might need to focus on??
    Thanks,
    Rob
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    look cafefully around the steering box where it bolts to the frame, check for cracks. Big problem area for these trucks.
    -Jeremy
    PS also have a buddy sit in the truck and turn the wheel from end of play to end of play and just look at every joint and see what moves and what doesn't.
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Check ball joints
    Dan /forums/images/graemlins/burb.gif
  4. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    if the steering arm has been off check that it is tight. check the u-bolts, not the u-joints.
