Just had a great idea [Sub enclosure/bench]
Discussion in 'The Garage' started by Ben B., Mar 12, 2007.
  1. Ben B.
    Ben B. 1/2 ton status
    Sep 1, 2005
    352
    Central PA
    I like my bench for obvious reasons, but I have no room for stereo equipment. Music is my biggest passion.
    So here's the deal.
    I have 2 Van captains chairs which are awesome. Then for the "bench" effect, I can make a sub enclosure that goes between the seats and sits at the same level, with padding on it. I can have subs and still have the whole bench seat effect!
    Opinions?
  2. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    what are you trying to stuff in said box?10,s 12,s 15,s:eek1:
  3. Ben B.
    Sep 1, 2005
    352
    Central PA
    2 10's, maybe just a single 12. not sure as of now. How come?
  4. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    I think what he's getting at is that there really won't be that many 'cubes' in an enclosure that would fit between the seats. It's been done before, but typically with maybe an 8" or 10" sub. The ones that hold a larger sub become too massive and ugly.
    Not a bad idea....just not as much room to work with as you might initially think.
    :usaflag:
  5. Ben B.
    Sep 1, 2005
    352
    Central PA
    I think there should be enough room for a 12 at least. I'll have to check it out.
  6. NoReGrEtS
    Nov 7, 2005
    848
    but with out the c.i.(cubic inches) that it needs it wouldn't hit right.
    Its not about putting a big woofer in and calling it a day, they need proper air space to work. each speakers has its own c.i. requirement
    I had a little standered cab Toyota that I stuffed two 12's behind the seat and it wouldn't hit hard. Just not enough room. My buddy build a box for one 10 and it would hit harder then mine.
  7. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    Biggest benefit of this is that you won't have a problem finding some wimmens to ride in the middle next to you. :waytogo:
  8. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    You can easily build a box for a properly powered single 12 between two captains chairs...or get a box for behind the seat...
    I run two 12's behind the seat in my standard cab...its a custom box but none the less you or a local audio shop could build it to fit perfectly in the space you have and still meet the minimum volume requirements for w/e subs you choose to go with.
    I really enjoy my two 12's but have lately been kicking around the idea of going to Astro Van captain's chairs and building an enclosure for in the middle...reason being is when they are behind the seat they sound good but you are really only getting the vibrations...literally it'll get almost twice as loud when I fold the seat forward...
    That being said a well built box with a single 10 or 12 w/o being blocked behind the seat will sound as good if not better than anything thats being stuffed behind the seat...Just my $0.02 though.
  9. NoReGrEtS
    Nov 7, 2005
    848
    Bass is meant to be felt not heard
  10. NoReGrEtS
    Nov 7, 2005
    848
    If you went from 12's to 10's it would hit a lot harder and because you would go to 10's you could get better woofers (10's are cheaper)
    putting 12's in a small area just does not work all that great.
    I was the same way why go 10's when you can buy 12's, but I bet if you look at what those speakers need for air volume those boxes are too small.
  11. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    No actually they are just right...and btw nobody ever said anything about $$$ so sure you can spend more and get different quality subs but that wasn't the point anywhere in the post.
    audio is such a personal opinion thing it's hard to debate it. In my opinion of course subs are meant to be felt but have you ever had subs behind the seat then swung the seat forward? If so you know what I'm talking about.
  12. NoReGrEtS
    Nov 7, 2005
    848
    *edit*
    Why waste the time:rolleyes:
  13. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    right...forgot about reading that post earlier...what subs and how big were the boxes?
