Just had a ride in 6.2 with a banks turbo and some other things done.......
Discussion in '1982-Present GM Diesel' started by 84CUCV, Aug 31, 2002.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    All I can think to say is I need a turbo!!!! That is a lot of cash. Mike
  2. BigDiesel
    BigDiesel Registered Member Premium Member
    Dec 31, 2001
    21
    Calgary Alberta, Canada
    What were the other things that were done?
  3. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    The one I rode in last jan. had the banks sidewinder (witch BTW had a huge square hole cut in the air box for increased air flow) and a single 4" stack coming through the bed. I could not BELIEVE that thing!! VERY IMPRESSIVE.
    rob
  4. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Any idea how much boost the Banks unit is pushing? Does it use a waste gate or is it free floating?
  5. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    Banks turbo is free floating, no boost controls of any kind. I've seen 10 psi max. I could probly get it to 11 if I had the fuel turned up a little more.
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    There is a turbo, custom exhaust. I think it was 4"-41/2." He even did custom headers. He worked at a machine shop where I got the ride He had some kind of propane kit. the motor was balanced. There was a bunch of stuff on there from a marine 6.5. I don't remember the name of the pistons. He did say they are hard to get. I haven't talked to him for a while. I will find out what else he did. Later Mike
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well with a banks turbo, a 4+ exhaust and propane, you should feel a big difference.
    I am preparing to add the propane to mine soon.
    /forums/images/graemlins/grin.gif
  8. BanksBurban
    BanksBurban Registered Member
    Mar 23, 2002
    88
    New Jersey
    Please excuse my ignorance, but what does the propane do?
    Is it the diesel version of nitrous?
  9. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    It catalyzes the diesel fuel, making it burn better and more completely whereas nitrous just is an artificial way to add oxygen to the combustion mixture.
  10. BanksBurban
    Mar 23, 2002
    88
    New Jersey
    How much is a propane setup?
  11. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Like blueblazer said, it helps the fuel burn better giving you a boost in power and MPG.
    propane injection
    Read it and then do a search for other companies, I think bulldog had a kit too.
  12. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    On the other hand, if you can do the work yourself, I had a thread going on about propane injection a couple of months ago. Do a search here and you will see someone posted a home made setup that should cost around 150
