Just installed my new
Discussion in '1936-Present Suburban' started by chvyhs, Feb 26, 2003.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Driveshaft/SLE. I wish I had a digi cam so I could show you it. I no longer have that humming vibration around 55-65 mph.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Awesome - where'd you buy all the parts? If you don't mind me asking, what kind of $$ we talking total?
    So, worthwhile mod in your mind (even if the vibrations aren't an issue)?
    What are the advantages? Basically so that if you twist off the rear shaft or blow up a u-joint without a spare you can drive home in front wheel drive without losing fluid? Thanks - gotta keep learning this stuff /forums/images/graemlins/grin.gif
  3. chvyhs
    Feb 12, 2001
    1,469
    I found them in the back of a Petersons Mag. It's http://www.driveshaftsuperstore.com/. I think I paid about $500 for an entirely new shaft. I had to drill for a 5/16 bolt 1" deep into the output shaft. Then you slide the new yoke on and bolt it in. This gives you full spline engagement on your output shaft. With my stock shaft I only had about 1.5" after the lift. Now my d-shaft has the slip shaft and a double cardan joint at the top. It's all 1 ton too!/forums/images/graemlins/burb.gif Like you said, if I blow the rear shaft I can still drive home on the front without loosing all my fluid. Plus I still have my stock shaft as a spare. I'm supposed to go wheelin this weekend, I'll let you know how it did.
