Just Installed Relay's For Headlights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jc71355, Mar 23, 2003.
  1. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    Just Installed Relay\'s For Headlights
    WOW what a difference. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif Everyone should do this. I had very little electrical experience before this and I made it through with no problems, not hard at all.
    Special thanks to Rugger03 for answering all my questions and DP_90K5 for drawing the wiring diagram. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  2. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    Re: Just Installed Relay\'s For Headlights
    Glad to hear that it worked out. Night and day difference, isn't there. no pun intended. Wiring wasn't as hard as you thought, and you probally feel you can tackle any electrical problem. Once you get and use a multimeter, it will be one of your most used tools.
    cheers, rugger
  3. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    For others here is a schematic for this.
  4. Krase
    Krase Registered Member
    May 19, 2002
    90
    Northeast ,Tennessee
    Can i ask the stupid question? Why do this why is the difference gained, sorry never heard of this? sorry just curious so had to ask
  5. Grim-Reaper
    7,385
    Atlanta
    To get rid of voltage drop and about 30 connections between the head lights and the battery. There is proabably 25 feet of wire between the battery and the lights. This way you get full battery voltage of about 14v when driving. Take a VOM and measure the voltage at the battery and then measure the voltage at the lights....you will proabably see 1.5 volts less.
  6. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    As you trucks wiring gets old it will "soak up" voltage as it travels along the length of the wire.
    In the case of your head lights it has to go from the alt. to the horn relay,from there to your headlight switch,from the headlight switch it travels a long distance to your head lights.
    The horn relay and headlight switch are 2 extra connection that age as well.
    All this old wiring and connections can lead to a thing called voltage drop.
    You may have 14.2 volts at the terminal on the alt. but by the time it goes through the old wiring and connections you may olny be getting 12 or less volts at the headlights.This leads to dull headlights.
    A relay will provide full voltage to the lights.It re-routes the power normally flowing through the old wireing and connections and takes it directly from the battery ot alt.
    The old wires activate the relay,this take a very small amout of voltage to do.It "triggers" the relay to start sending full voltage to the lights.This leads to nice bright headlights.
    Hope that made sense. /forums/images/graemlins/grin.gif
    If your wiring is in good condition and your not running high wattage lights you don't need to do this.
  7. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    I decided to redo my wiring when the circuit breaker started tripping every few minutes. I didn't have any shorts, just old wires drawing too much current. I have quad headlights, so I hooked up 4 low, and high beams. I used one 30 amp fuse and relay per side for low beams. I now have four low beams, and I ran one 70 amp maxi fuse and 70 amp relay on each side for the high beams. These lights now give off so much light with the low and high on at the same time, that I don't have to use my 100 watt off road light much at all. And I am just using standard halogen bulbs. Only thing I had to do was use 10 gauge wiring for the power, and 8 gauge for the ground. One of the best things i've done to the trucks in a while. /forums/images/graemlins/burb.gif /forums/images/graemlins/k5.gif
  8. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    How much wire was needed?
  9. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    In reference to this picture: [​IMG]
    I assume this diagram is for k5's with single lights low/high in one light. I have an 82 with the 4 light low on top and high on the bottom. Is there a diagram for the 4 light setup?
  10. RatMan
    RatMan 1/2 ton status
    Jul 27, 2002
    270
    Marietta, Georgia
    yes, someone made a diagram for the 4 light system. i have a copy of it, but im not on my home computer right now. you could probably find it in a search, but ill try to get it up for ya later.
  11. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I have an 88 Burb & have thought of doing this. The only other thing I want to incorporate into mine is when I hit high beams, I want both high and low to come on. How would I do this different to do this?
    PS - This is an extremely helpful and pratical thread for EVERYONE!!! A persone doesn't even need to have a 4x4 to appreciate this!!
    /forums/images/graemlins/burb.gif /forums/images/graemlins/thumb.gif
  12. jwingfield2k
    jwingfield2k Registered Member
    Jan 29, 2003
    29
    Richardson, Texas
    Splice your high beam wire into your driving light wire.
  13. RatMan
    Jul 27, 2002
    270
    Marietta, Georgia
    ok, here it is....
    this is the relay setup for the 4 headlight system. in addition to simply making your healights brighter, this setup turns all four lights on when you put your high beams on /forums/images/graemlins/thumb.gif so basically, high beams means highs and regular driving lights /forums/images/graemlins/grin.gif
  14. jberg62
    jberg62 1/2 ton status
    May 7, 2001
    104
    Long Island,NY
    If I were to walk into pep boys or wherever tomorrow to purchase some relays in order for me to do this awesome looking setup, exactly what kinds of relays would I need to purchase?
    I mean would I ask for single pole double throw...or single pole single throw?
    Also, these are 30 amp relays correct?
    I'm most definitely wanting to do this as my headlights are cronically on the dull side.
    I've got quad headlights and for the time being don't even have my highbeams hooked up.
    Thanks for the info!
  15. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    I got my stuff from Daniel Stern Lighting . They are hella 30 amp dual 87 relays. They also came with connectors and a screw in interlocking mount for the Relays.
  16. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    Humm... I can't remember how many box's of wiring I needed, I bought a bunch, all the store had was 6'. I know I ended up needing alot more wire than I expected.
  17. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    That will work.
  18. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    Gonna add this to my list of to do's, so who want to do a write up? /forums/images/graemlins/deal.gif
  19. supersize75
    Sep 27, 2002
    2,638
    bring back a good post /forums/images/graemlins/thumb.gif
  20. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    Thanks for bringing this back up. Looks like I got some wiring to do. I have almost 1.8 volts being dropped thru the wiring. Didn't Painless Wiring make a kit like this?
