Just my luck
Discussion in 'The Garage' started by adamforsythe, Apr 15, 2006.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Ever since I got my truck back it's had a ticking sound coming from around the pass side valve cover. Today I was working on anything and everything in my engine compartment. So I ripped my valve cover off started the truck and starting looking for the tick. I checked every valve nothing. So I shut the truck off and took every pushrod out and rocker. Not a thing wrong. So I put every thing back. Started the truck up still there. So I started checking the bolts on my head (exhaust) and a couple of the bolt holes where stripped. So I have a exhaust leak not a bad valve. So tomarrow I will replace my plugs and take my heads of and clean them then retap the holes.
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    good luck. Let us know how it goes. I assume you will have to drill the holes to the next size up. I'm not sure what size drill bit and what size tap you will need. I know when I tapped my head for a new stud, I took it SLOW.. making sure to back it out and clean up the shavings often :wink1:
  3. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Yea I have taped just about every hole on my truck So I am a pro:D . I hate taking my headers off it's right up there with getting all your teeth pulled while you get kicked in the balls. But what ever. At least I can clean all of the oil and dirt off from my red block. Make her shine.:bow: :D :o :laugh:
  4. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    thanks for the new quote :bow:
  5. duanel
    duanel Registered Member
    Feb 20, 2006
    59
    spokane WA
    that is kinda funny since I have had a ticking too that I was thinking was in the valve train and then yesterday I figured out it was a crack in the weld where one of my header tubes connects to the collecter. Sorry you had to do so much to figure yours out though.
