Just my luck
Discussion in 'The Garage' started by bigoltrux77, Nov 2, 2006.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    So today was the first day ive been able to start working on my truck since ive been back. I push the truck into the Auto Shop where its been sitting at for the past 9 months (on post) and start to take off the TBI Intake to put on the new carb one. When i get the intake off i realize it has water in it. Not alot, but enough. So now im sure its not going to work. Is there anything i can do about my water problem? Or is this motor shot? Someone please help, im pretty sure i cant afford another engine.
  2. bigoltrux77
    Jun 12, 2002
    318
    Fort Polk, LA
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    where specifically was the water at? you do know that there are coolant passages in the intake, right?
  4. bigoltrux77
    Jun 12, 2002
    318
    Fort Polk, LA
    Well They are in just about all the ports, intake and exhaust. I read that i can take out the plugs and crank her up and it should shoot all the water out. I know it wasnt ran with water in it, its just from sitting in Louisiana for 9 months getting rained on. Is this right? Should i use any kind of Wd40 or something of that nature. Oil change is a must i know.
  5. bigoltrux77
    Jun 12, 2002
    318
    Fort Polk, LA
  6. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Was the motor sitting outside in the rain with the throttle body exposed?
  7. bigoltrux77
    Jun 12, 2002
    318
    Fort Polk, LA
    The truck was outside with the hood unbolted but on. i guess the wind had blown it off during a storm, so some water got in the manifold, there was not Throttle body on it, just a Rag that soaked up as much of the water as it could.
  8. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    use compressed shop air to blow it out, wear safety glasses or a shield, blow it out, spray some blaster down in the cylinders with the plugs out and crank it to make sure it isnt TOO rusted up... should be fine...
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    personally, you've got the manifold off, yank the heads and have them checked out. you're into it this far, might as well fix it right the first time.
  10. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    a soaked rag is nothing. I had the carb off to change to a truck avenger. MY brother tried to start the truck to jump start his car. Pumps fuel everywhere, the IGNITES! Everything from the fan shroud to the steering wheel is gone. Fire department put more then a few gallons of water down the intake, along with with every where else. No way of cranking the engine cause the wiring harness is toast.
    Swapped the cab and wiring harness. crank the motor over and spew only a little water. change the oil and filter. she runs fine.
    surface rust comes quick. really bad damaging rust takes time. I'm sure that I not the only one on here hoping that a good cleaning out crank will be all you need. Good luck and thank you for serving.
