Just Ordered New GM Crate 350-290 HP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by df, Sep 30, 2004.
  1. df
    df Registered Member
    Nov 9, 2003
    13
    New York NY
    Is anyone familar with this engine? According to Dealership it is new to the market. Supposed to be able to transfer everything from old 305. What should I replace for new engine? ie; water pump, etc?
    Thx
  2. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    Definitely the water pump & thermostat. Also if your using the same radiator, get it cleaned out by a radiator shop. If I'm putting a new motor in, I don't like the coolant passages getting yucked up from old stuff.
  3. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    Agreed, the cooling system overhaul is a MUST!
    I would suggest doing a complete tune up and replacing all of the filters, hoses and belts.
  4. df
    Nov 9, 2003
    13
    New York NY
    I installed a new radiator in November of 04 and have driven maybe 3-4 K since. Will that work? Whats the deal witht the flywheel? needs to be ground down supposdly?
    thx
  5. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    You just installed the new rad. in Nov. of 04? I thought it was only Oct. 04 /forums/images/graemlins/eek.gif Anyway, just flush out the rad. real good with the garden hose until only clear water comes out. I agree with the new hoses, belts, h2o pump, and T-stat.
    I don't know about grinding the flywheel, unless you have a manual trans and then it gets refaced. But I had to replace my flywheel and it only ran about $70 new, so you may be better off just picking up a new one for your new application.
    Where in NY are you?
  6. mrbill
    mrbill 1/2 ton status
    Jul 1, 2003
    170
    Sugar City, Idaho
    I did the about the same a year ago. You may need to replace the distrib.
  7. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    cool! /forums/images/graemlins/cool.gif i've been eyein that motor. post up when you get it running and let us know what you think of it /forums/images/graemlins/thumb.gif
  8. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,029
    856
    Pinckney, MI
    My crazy friend just put in a 350 zz4 in his YJ wow does that thing move 355hp and 404lb of torque! and this is why we call him crazy, taking his stock yj and doing this
    Crazy Click here
