just passed smog....barely.
Discussion in 'The Garage' started by Jonny-K5, Oct 12, 2005.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    just the the blazer smogged today. even with a brand new cat, new plugs and new oil change i barely squeeked by. max emissions were 112 PPM @ 15mph, and the truck did 111. the tech said its basically unburned fuel(running rich). she did better for the 25mph reading. what could be caussing this? the truck has always kinda smelled rich at idle, at least for the 4 years i've owned it.
    what are some things that i could check?
    oh yeah, the truck came with a performance chip. forget what brand but it requires 91 octane.
    could the chip be the culprit?
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    maybe the chip wasnt programed right in the first place???? :thinking:
    congrats on passing :waytogo:
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Just curious, was the truck fully warmed up? The cat has to get to 1200*F before it works.
  4. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    i was driving around for an hour before i pulled into the smog station. pretty sure it was warmed up. i do have a 180* stat in for the chip instead of the stock 195*. maybe that had something to do with it.
  5. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    What year and what was the CO readings?
  6. REDCRO_REDNECK
    REDCRO_REDNECK 1/2 ton status
    Apr 7, 2005
    241
    mo
    If you are using the stock chip your t-stat might be your problem. stock computers run better, and get better economy @195. All of mine have anyway.
  7. dyeager535
    26,979
    If it's an off the shelf chip (hypertech, etc) get rid of it, piece of junk anyways. Increased octane because the timing is bumped up, that's essentially all they do.
    Lower octane, higher thermostat rating, and stock chip will more than likely bring it back to where it should be.
    Can't reiterate enough how crappy those aftermarket chips are.
