Just picked up an O/D unit for the crew cab...
Discussion in 'Tow & Trailer' started by BlueBlazer, Jan 17, 2005.
  1. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I know a guy that is using one of those in Colorado. He didnt like it. Pain to split shift and it leaked terribly when he first put it in. Ended up making a makeshift seal on the input to keep it from leaking. You will have to double clutch to split shift which can loose more momentum than you want. Also, you end up needing to cut off your current shifter handles and modify them so they dont hit the seat. They get pushed back 7" with that set up and dont work well anymore.
    On the positive side you saved a couple hundred bucks over buying one new from AA.
  3. BlueBlazer
    Feb 15, 2001
    1,940
    Do you know the vintage of his box? This one is brand new so hopefully any design problems have been fixed. Also, the gears are synchronized so no double clutching needed anymore. I have captains chairs in the crew cab, so no seat to shifter interference problems to worry about. Hopefully there wont be any leaks, we shall see though. Anyone else with experience with these?
  4. kennyw
    Jun 9, 2002
    13,224
    94
    He said his was supposed to be syncro'd as well, but it didnt work that way. I can probably dig up his email address so you can email him directly...
  5. BlueBlazer
    Feb 15, 2001
    1,940
    Just got this done last night, and man what a difference. I had to shift through all 8 gears just to see how fast I could do it, and all went smoothly. Ive found that if I leave it in OD I can use all 4 trans speeds and it accelerates much smoother without near as much of a drop between gears not to mention the 700 rpm drop at 65 mph. Well worth 750 bucks I think.:saweet: :crewcab:
  6. fordcummins1
    fordcummins1 1/2 ton status
    Jul 8, 2004
    161
    Northern IL
    I rode in Tyler's rig last night, and it does go down the highway damn nice now.....should tow very well with the split shifts. Definitely a slick unit.
  7. kennyw
    Jun 9, 2002
    13,224
    94
    Any trouble split shifting?
  8. BlueBlazer
    Feb 15, 2001
    1,940
    Nope. Just takes a little extra time to move both shifters, but I am getting pretty good at it.
