Just pulled code and...
Discussion in 'The Garage' started by BlazerWheels, Jan 21, 2005.
  1. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    I got a 44
    as per Haynes ---> Lean Exhaust - Check ECM wiring Connection terminals. Have the fuel pressure checked. Check the oxygen sensor wire. Check the carburetor gasket, vacuum hoses and intake manifold gaskets for leaks. Replace oxygen sensor (Component replacement may not cure the problem in all cases. For this reason, you may want to seek professional advice before purchasing replacement parts.)
    Here is what recently happened. New heads, new exhaust manifold (pass side), replaced and fixed many vacuum lines. Check engine light never came on before....but does now after about 10 - 14 minutes of freeway driving.
    Has always had a slight hesitation on take off, idles slightly irregular at a stop.
    Any ideas??? Should I change the O2 sensor and see if that helps??:confused: :confused:
  2. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    If you do, Don't waste your money on Bosch...get a Delco....Friggin Bosch was bad right outta the box...cost me a second Inspection fee ($35)...Delco was $5 cheaper and Worked....Plus I didn't get my money back on the Bosch so I was out $35 reinspection fee and $45 for the Bosch Piece of doodoo
  3. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    I'm thinking you have a vacuum leak somewhere. A vacuum leak can cause an engine to run lean. Check all the vacuum lines you recently replaced first for any vacuum leaks. One of the lines may have become disconnected. Then check the intake manifold for vacuum leaks since you removed that as well when you did a top end on your engine.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Last time I got a code 44 putting in a new 02 sensor cured the problem.
    Harley
  5. Fierospeeder
    Fierospeeder Banned
    Sep 17, 2001
    315
    Illinois
    check to see if your EGR valve isn't getting stuck
    and it is possible for you to have an exhaust manifold leak.
  6. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    my money is on either O2 or EGR, if theyre both old, might as well replace em. one at a time of course, so u know what was causing it
  7. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    I think you are all wrong. I think it is the left rear wheel causing the problem. :D
  8. BlazerWheels
    Feb 13, 2003
    587
    California
    Nope, can't be...it was replaced when it refused to start. Replaced the right one when it overheated. The front 2 are new....so that can't be it.:D
  9. BlazerWheels
    Feb 13, 2003
    587
    California
    EGR has already been checked...all ok. I figure that I will probably change the O2 and see. While I am at it, I wil check to see if I have an exhaust leak...
