just put my 700r4 in and its not shifting right?
Discussion in 'The Garage' started by protechk5, Nov 16, 2004.
  1. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    just my a 700r4 that i got from a guy on here that has less than 10,000miles on it, im pretty sure i put it all in right, but its not shifting right and its kinda making a buzzing nosie, i thinks it just the tv cable? could it be anything else? i might just take it in the shop i know to get them to do the tv cable.
  2. crazy427
    crazy427 1/2 ton status
    Mar 10, 2003
    979
    Edison , NJ
    if the pressure regulator is sticking it can make a buzzing sound. make sure you have the cable adjusted right and i would put some lubeguard or other synthetic additive in there to help smooth it out. how long did it sit before you installed it?
  3. protechk5
    Sep 26, 2004
    2,015
    VA
    i think it did sit for a while
  4. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    It is imperative that the TV cable get adjusted correctly or you will get goofy shifts at the wrong time and eventually destroy the transmission. /forums/images/graemlins/frown.gif I would probably take it down to a tranny shop and have them make sure the TV is correct along with anything else easy and cheap for them to check.
  5. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    That tranny was from me. Let me know how it goes and If something is wrong PM me.
    Keep me posted. (no pun intended)
    It did not make any noises prior to pulling it from my friends truck. /forums/images/graemlins/thumb.gif
  6. semper-k-five
    semper-k-five 1/2 ton status
    Aug 16, 2004
    326
    Tulsa, OK
    what did that tranny come out of??? depending on the vehicle it may have been in before, you will have to move the check balls around in the valve body...i replaced the 700r4 from in my vette w/ one from a newer model firebird and that's what i had to do...you can open the tech manny for the 700r4 for your Blazer application and it should have a check ball diagram...make sure they are in the right places....
    Looking at these posts, that something you may want to spend the time doing..
  7. semper-k-five
    Aug 16, 2004
    326
    Tulsa, OK
    well, i didn't read the post right above mine!!!! disreguard what i wrote!
  8. protechk5
    Sep 26, 2004
    2,015
    VA
    yeah i think its just the tv cable, im going to get someone to adjust it right for me and hopefully it will be good as new
