Just Thought I would Post Some Recent Pictures Of My Progress
Discussion in 'The Garage' started by ProJunkRacing, Nov 27, 2005.
  1. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    Well Here are some Recent Pictures Of the progress of my rig
  2. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    1 More
    I have to find that stupid seal For the T case Adapter , Put the trans back in then Finish Up Figuring Out my Brakes , then check it all over , and it is done .
    Hoping To have it on the trail here next Month
  3. Ancient4X4
    Ancient4X4 Registered Member
    Feb 25, 2005
    82
    ND, USA
    It doesn't let me look at the pictures.
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    What did the seats come out of?
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    join up and you can see them.
    i pulled the seats out of a '94 Grand Am.
  6. aduff85k5
    aduff85k5 Registered Member
    Dec 31, 2004
    91
    florida panhandle
    looking good. whats the lift and what tyres you running. the front of mine is cut just like yours. i got 39.5x15x18 boggers and and 6 ich lift. but it's a little more than i want. i'd like to come down to some 38's and bring the tyres in a little. they stick out so much right now and rub alot.
  7. Robert D
    Robert D 1/2 ton status
    Oct 2, 2005
    261
    Austin, TX
    Nice looking rig. When I had my intake off a few weeks ago I used a product leftover from using on my brothers' 76 Porsche. It is a rust spray which turns rust black (wire brushed the tin first). I then sprayed the tin with flat black paint, and I cleaned up the hose with simple grean and a brush. It's amazing how much cleaner everything looks now.
  8. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    6" Tc Easy Rides in the Front Cut Fender's
    6 "Shackle Flip Rear and NOS Rear Springs
  9. Ten_Bucks
    Ten_Bucks 1/2 ton status Premium Member
    Dec 9, 2004
    892
    46
    Placerville, California
    Looks good!
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    they're not NOS, they're stock 52s.
  11. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    nos meaning as in new springs they aint old and crummy
  12. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Right on dude, lookin good, its gettin there. Keep up the good work!
  13. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
  14. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Are you running a pre-TBI block with the serpentine system? If so, did you have any problems with the couple of missing mount points?
  15. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    looks sweet bro :bow:
  16. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    Yeah It is a 70's 350 Block
    The Serp Setup I got Is newer It actually Came Of A 4.3L 1500
    It Does miss a Few Points BUt It Is plenty Strong And Holds up for me Just Fine I actually have another serp setup but no pumps or anything
    It uses an Air Pump Tho which i was trying to stay away from.
    Mine Has no mount for Air tho
    Thanks For the comments
  17. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Thanks for the info. Whenever the temps get above 10 degrees around here (no heat in garage) I will mock up my TBI serpentine to the small block 400 sitting in the garage and see what I need to install it. I am not going to use the AC so I'll need the idler pulley...but I digress.
    I hope it works out as good as yours did.
  18. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Take those blue valve cover tighteners OFF. They can vibrate loose, fall off and generally cause one hell of an oil leak. Don't ask me how I know. Lets just say they cost me a 4 bolt 350, many years ago.
  19. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    Yeah well i got the A/C Pump there but Have no A/c Just in free clutch used as a idler (on Board Air soon)
  20. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    a bolt can rattle out too. most of us are more observant, and would quickly notice a valve cover leak. if a valve cover leak cost you an engine, you were very neglectful in noticing the leak.
    i put 30,000 on my 355 i built when i was in HS, and it had 20,000 on it with the chrome valve covers and hold downs on it before the rebuild. i even used cheap cork valve cover gaskets, and had zero problems that would have threatened the life of the engine.
