just to be sure...
Discussion in 'The Garage' started by Pow06er, Jul 27, 2005.
  1. Pow06er
    Pow06er 1/2 ton status
    Apr 9, 2005
    188
    ne, ohio
    after talking the tire guy im kinda second guessing myself
    I am wondering if i will be ok to do 4" TC with 15x10s that have 4" BS with 35" toyo mt's that measure 34.8x14.4 according to their site. Im not gonna be real serious offroading but will i rub bad?
    my current measurements with stock 31's that measure 29"
    front is 36.5" and rear is 37" thats with the top off too
    Im also wondering if it will be bad to run a 1" zero rate in the front for added safety against major rubbing my main concerns are the front angles
    I suppose i could trim it a bit but i dont want to hack it to bad
  2. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    you won't rub with 35s on the street unless you take a driveway fast...shouldn't EVER rub going in a straight line.
    Your angles with 4" won't be bad...5" starts gettin on the verge of bad...but im runnin 7" (with a tcase drop) and the angles look bad, but ive yet to blow a u joint and ive beat on the truck a lot. stock front shaft should be fine, rear may need lengthening.
  3. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    you're gonna rub like hell with that wide of a tire on that wide of a wheel if you're only planning on minimal trimming.
