K-10 Turns good to right not left
Discussion in 'OffRoad Design' started by TJS, Jan 10, 2002.
  1. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    Ok I got this truck a month or so ago. It had a lot of probs which I have been fixing. The one thing is that I am not sure on is that it turns nice and sharp to the right but not the left. To get into the parking garage where I work (left turn) I have to stop and back up and turn left again. It has a 4" lift on it and
    the higher steering arm. The drag link is not level though. The front part of the draglink at the pitman arm sits a tiny bit lower than at the back part of the drag link. My thoughts are to adjust the steering is to take in at the adjustment at the drag link. Any thoughts here on what I should do. I also have a stock steering arm for this truck, should I change that as well or try the adjustment first. I am pissing people off behind me in the parking garage and I want to cure this ASAP.
    Thanks for all the help.
    T.J.
  2. XtrmChevy
    XtrmChevy 1/2 ton status
    Jul 14, 2001
    148
    Finland, Europe
    The draglink is too long, try to shorten it. Should cure the problem.
    1981 K20 350/400/208/205 D60fARB & 14bFFDETROIT 4.10 (UNDER CONSTRUCTION!!)
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Just adjust it at the draglink till you get equal steering to each side. Keep in mind it will never be exactly equal due to flex of the bushings and frame, etc, but you can get it really close.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  4. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    thanks for the info. I was able to work on it today and shorten
    the drag link. I think I made it one turn too short now. I will readjust it later this week. Thanks for all the help.
    T.J.
