K-30 axles ..will they fit
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bckinblk, Jun 21, 2002.
  1. bckinblk
    bckinblk 1/2 ton status
    Jun 12, 2002
    305
    bristol connecticut
    Will 85 k-30 axles bolt directly into my 88 k-5 without mods??? If not which years will be swappable.thanks
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green">You'll have to move the spring perches in on the back, K30 fraes are narrower. You may also need to address the u-joint size on both driveshafts, and the brake lines as well. 10 bolt uses the same thread on the caliper end as the 60, so you should be OK up front, not sure about the back though. Make sure you get spring plates for the front too, they're hard to find and kind of spendy.
    There's other stuff that may need to be addressed also, but the short answer is - No, they are not bolt in, and there are no 1 ton axles that will bolt right in with no mods, they will all need something. A 14 bolt from a 3/4 ton will bolt in without moving the perches, but you still may need to address the u-joint and brake line.</font color>
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    The front axle will not bolt up and therefore you need to ship it to me so I can dispose of it properly.
    /forums/images/icons/laugh.gif
    Naw, the D60 spring perches are like 1" taller than 1/2 or 3/4 stuff, thats about it for the front...as for the rear see above message...
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I'm not sure what years that they did or didn't make dually K-30's, but make sure that the axles you get are from a single-rear-wheel truck. The dually axles aren't the hot ticket for this swap. /forums/images/icons/shocked.gif
  5. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Yeah! Ship all dually axles to Michigan and we'll properly dispose of the offending items /forums/images/icons/grin.gif !
  6. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I just swapped a 3/4 ton 14b ff into my '76 tonight. The brake lines bolt up no probs. The u-joint is Napa part # 348. The only issue I have is the shock mounts need to be relocated and I think the e-brake cables are to short...I was tired by the time I got to them, so might have just gave up early. Gonna look at it alittle closer tommorrow.
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    frames arent narrower just the spring hangers are different
  8. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    mj is right, the spring hangers are where the difference is. Also, the shock mounts will have to be moved on the 1 ton axle.
