K boys need help with a snowmobile.
Discussion in 'The Lounge' started by dogdaysunrise, Mar 28, 2006.
  1. dogdaysunrise
    dogdaysunrise 1/2 ton status
    Jan 19, 2005
    2,719
    Winterpeg
    Well actually I need helping finding some good information on 2 stroke motors. Post your fav links!
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    what do you need to know bout 2 strokes, im a general textbook of info...:D
  3. dogdaysunrise
    Jan 19, 2005
    2,719
    Winterpeg
    Well I have an 81 Ski-Doo Blizzard with a 503 in it. Baisically the points close up on it. A guy at work was saying something about a pin on the crank, and if it wears down the points will keep closing up.
    I havent really touched it at all, just need some sort of basic info to know what im looking for.
  4. 79k20350
    Nov 22, 2004
    7,757
    Ct
    hmm..old motor. never worked on a skidoo myslef but should be simmilar. never seens oints on a 2 storke, magneto and igntion coil. typically on the (if your sitting on it) left side is the ignition side. is its not htere then its on the other. (should be on the oppostie side of the clutch) most ive seens turn a magneto directly off the cranks. i imaginge the contact could be work. pull the cover off and see what you can see. you will usually need a special puller to pull the magneto itself.
  5. dogdaysunrise
    Jan 19, 2005
    2,719
    Winterpeg
  6. CustomChevy
    CustomChevy 1/2 ton status
    Jun 29, 2005
    4,328
    Kitchener, Ontario, Canada
  7. dogdaysunrise
    Jan 19, 2005
    2,719
    Winterpeg
    yea i read through that already. I know there isnt much to em, just more concerned with the ignition part of it.
