K&N Air Filter
Discussion in '1982-Present GM Diesel' started by 6.2L Jimmy, Jul 21, 2002.
  1. 6.2L Jimmy
    6.2L Jimmy 1/2 ton status
    Jan 2, 2002
    164
    Montreal,Quebec
    Hi Everyone,
    Question...has anybody here with a naturally aspirated 6.2L ever put on a K&N air filter( i imagine so)? I washed out the air filter box and repainted it then re-installed it and replaced the old paper filter with my new K&N and started up the truck and all is fine but now when I hit the accelerator the truck really goes but is making louder noise (a growling like sound that is relative to throttle position kinda sounds like a gas engine)from out of the air filter box...is this normal???
    Is this the sound of the increased CFMs? /forums/images/icons/shocked.gif Everything is hooked up right. Thanks in advance.
    P.S the trucks smokes a lot less when under load now /forums/images/icons/grin.gif
  2. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    I remember reading something about Dodge voiding all warranties on their Diesels if someone installed a K&N air filter!
    It was on the Diesel Page mailing list
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Whenever I replace my air filter, I notice a louder "growl" out of my 6.2 at higher RPMs. I'm pretty sure it happens because the motor is breathing better. And because a K&N breathes better than a normal paper filter, I would assume that engine noise could be louder than normal with one installed.
  4. Can Can
    15,552
    136
    If that's true, it's ridiculous. /forums/images/icons/tongue.gif It sounds like Dodge was using K&N as a scapegoat for some problem they had.
  5. calcide
    calcide 1/2 ton status
    Dec 21, 2001
    283
    I've read an article or two concerning how poorly a K&N filter works as a filter. Supposedly it doesn't filter as well as a paper filter until it "clogs" some (filter media has bigger holes), then it's airflow is restricted.
  6. kickinasphalt383
    kickinasphalt383 1/2 ton status
    Dec 6, 2001
    224
    Michigan
    yeah, i pulled my k&n out and put a paper filter back in because the paper stops more dirt
