K10 Weight ??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigmack, Aug 21, 2002.
  1. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Anybody know what a stock '79 K10 with a 350 weighs ?
  2. 76chevy
    76chevy 1/2 ton status
    Aug 16, 2000
    246
    Utah
    Not sure, but it should be posted on the inside of the drivers door opening. Should be on a metal plate by the door striker.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Short or long bed?
    Long bed should weigh around 4400 lbs.
  4. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    How about a short bed? /forums/images/icons/confused.gif
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Not real sure but I would guess it could be around or less than 500 lbs. difference lower than a long bed.
  6. outlaw612
    Feb 11, 2001
    2,342
    I figured these trucks were heavier than that. Thanks for the info.
  7. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    This wood be the GROSS vhicle weight.
    I would guess a 350 is about 300-400lbs, if you
    put it the bed, the truck and 350 should weight
    about 4000lbs. +/-500
    Good luck
  8. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    I weighed my truck way back and it was 6036 lbs. That was with 454,TH400,205,D44,14FF,38's and me. Now it's even fatter because of the D60,44's and me! /forums/images/icons/shocked.gif
  9. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    my blazer weight 5280 the last time i checked
    hope this helped!!
  10. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Before I put the 454 in my Blazer, it weighed 5400 pounds. That was also with a soft top and 39.5's.
  11. bigmack
    Jan 3, 2002
    478
    Tennessee
    It's a short bed.
  12. BigMac
    BigMac 1/2 ton status
    May 27, 2002
    397
    Fremont, CA
    mine ways 5100 lbs.... for now...
  13. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    My longbox 84K10 with a 350/700R4/NP208 and ten bolts weighs 4420 pounds with a quarter tank of petrol and no spare tire. It's also got a 90lb bed mat in the bed.
    My friend's shortbox only weighed 150lbs less than mine. I don't remember what he had in it/on it.
    This was weighed on a set of scales at a gravel pit so it may not be all that accurate.
    Hopefully this is close enough for your purposes.
  14. bigmack
    Jan 3, 2002
    478
    Tennessee
    Thanks for all the responses guys. I think I can come up with a rough guestimate now. /forums/images/icons/cool.gif
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My 1 ton long box 2 by weighs 4900 lbs empty with a half a tank of gas so I bet a shortbox 4x4 weighs at least that much.
  16. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    1 ton has a heavier frame and the rear end weighs over twice what a 1/2 ton rear does...
