K15 to K-5 axle swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Whassup, Feb 9, 2001.
  1. Whassup
    Whassup 1/2 ton status
    Feb 2, 2001
    140
    Wyoming, USA
    will swapping the rear from a K15 to a K-5 require me to move the spring perches to bolt it on to the Blazer?
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    From what I understand it should be a direct swap.
    But measure everything first to make sure.
    K15 and K5 are both 1/2 ton.
    Good luck
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  3. Whassup
    Feb 2, 2001
    140
    Wyoming, USA
    Thank you. I was thinking the same thing, since both are 1/2 ton it should work, the only difference being the Blazer rear is slightly narrower. I might as well go get to work so i can get on the road again
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The rear axles should be the same width if they are the same model (ex. 10-bolt, 12-bolt, etc...).
