K20 10Bolt front/14BSF rear axle set + D61 F*rd rear
Discussion in 'Suspension | Axle' started by jolane, Jul 2, 2006.
  1. jolane
    jolane 1/2 ton status
    May 27, 2004
    Just removed and replaced with a D60/14BFF set...
    10B 8-lug front axle: 4.10:1 I believe (can check), Warn hubs, 4" raised steering arm with drag link (new ends and sleeve ~400 miles ago), in great condition. No calipers. New pass side ball joints in knuckle (top and bottom). Make offer.
    14B semi-float rear: drum to drum, brakes work great including parking brake, 4.10:1 I believe also (matches front), runs great. Make offer.
    Both axles off running vehicle and work as expected. No hard wheeling (really!), street driven Burb for picking up building supplies, etc.
    ***STILL FOR SALE***
    Also have 81 Dana 61 from a 2WD ford truck. 3.73:1 I believe, semi-float, drum to drum, also from running truck. Seems to have a locker, but have not opened to verify. Make offer.
    These are all located in Albuquerque, NM 87120. I need this out of here...please...too much stuff already.
