K20 and steering brace?
Discussion in 'The Garage' started by txbartman, Jul 24, 2002.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    One of the first mods I did to my Jimmy after lifting it was to install the ORD bolt-on steering brace. My "new" K20 has 36 TSLs but no steering brace. The proportioning valve on it is positioned a little different which would cause the installation of a brace to be quite a bit more intensive. But, it would still be less work than repairing the frame later.
    My question is does a K20 need a steering brace? I have heard these frames are a little thicker and stiffer. What do y'all think?
  2. BigMac
    BigMac 1/2 ton status
    May 27, 2002
    397
    Fremont, CA
    I think the brace is cheap insurance.
  3. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    The K20 that I had was cracked out BAD and it only had 30" tires on it. I wouldn't gamble with it. It's a lot cheaper now to put the brace in than weld it up THEN put the brace in. The prop. valve might be in the way a little, it was on my 89 Blazer, but with a little creative playing, I made it all work.
