K20 D44 spicer hub assembly question - any gurus out there?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AussieK5, Jun 16, 2002.
  1. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    Theres a cup washer that fits between the outer bearing and the hubs spring. Which way does it sit?
    1.Should the lip turn out to the spring (and then will sit flush on the bearing)
    2.Or should it face inwards (and rest on the bearing cup edge leaving the spring to sit on its backside).
    Ive run it both ways to check wear but my experiment was stuffed due to an un-related operator induced mechanical %^&* up. /forums/images/icons/blush.gif
  2. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    some drawings will show it facing inwards but I install them facing out.. it really doesnt matter.. I prefer it to cup the spring that sits right there.. there is nothing to be protected behind it. I have seen them both ways with absolutely no ill effects either way.
    mike
  3. AussieK5
    Jun 17, 2001
    316
    A land girt by sea
    Thanks for the advice Mike...I can now go get busy in the garage! /forums/images/icons/grin.gif
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Do you have a pic or link to a pic of the full time drive flange assemblies. I found some at the wreckers for emergency use but I don't have any cupped washer. All that was there were the spring, drive flanges, then the cover.
  5. mike reeh
    Jul 23, 2001
    752
    San Diego, CA
    I scanned these in just now:
    Part-time D44 and Full-time D44
    Theres also one for D60 but I wasnt feeling that generous /forums/images/icons/smile.gif
    hope they help... you can see #9 & 16 which they refer to as the pressure plate.. the cup is pointing in.. I think thats bogus /forums/images/icons/wink.gif
    I left em real high resolution, hope you like em
    mike
