K20 FUEL GUAGE WIRING!!!!!!!!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AzzKicker, Feb 1, 2003.
  1. AzzKicker
    AzzKicker 1/2 ton status
    Jul 28, 2002
    265
    Edinburg, Tx
    My truck came factory with 1 tank. The PO installed a 2nd tank with a switch. Today I go pissed and removed the switch, cut the wires out and removed everything. WHAT A DUMB MISTAKE. My truck stays on etc. But my FUEL GUAGE is at the 3 o'clock position. My question is How is the fuel guage routed. The wire from the tank connects to what?
    My guage is teh factory type that connects via 3 bolts into the cluster pannel. I take it one is for ground, the other power, and the other goes to Gas Tank.
    Am I correct?
  2. AzzKicker
    Jul 28, 2002
    265
    Edinburg, Tx
    ANYBODY /forums/images/graemlins/frown.gif /forums/images/graemlins/truck.gif
  3. dyeager535
    26,976
    Do a search for posts in the last two weeks by me with the words "wiring diagram". MJ has posted the '85 wiring diagrams there, the dual tank setup SHOULD be present.
    With a dual tank setup, the "valve" on the frame is what controls most everything, the wires from the sending units run to it, so when you hit the switch, the gauge is reading the correct tank.
  4. AzzKicker
    Jul 28, 2002
    265
    Edinburg, Tx
    I figured it out /forums/images/graemlins/smile.gif thanks though.
