K20 Running High RPM's on Freeway
Discussion in 'The Garage' started by mendo, Oct 24, 2006.
  1. mendo
    mendo Registered Member
    Oct 22, 2006
    37
    Santa Barbara, CA
    My truck has a 350 and a bowtie overdrives stage II Tranny ( http://www.bowtieoverdrives.com ). 38x12.50 Swampers and 4:10's. It used to run at ~ 1700 RPM's on the freeway and then my brake booster went bad so I replaced it and now it runs at ~2400 RPM's on the freeway. Its like its not shifting into overdrive but I can feel it shift into all 4 gears. Any idea's on what happened? Thanks
  2. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
    It sounds suspiciously like the mechanism for kicking into overdrive was disconnected or mis-adjusted when you did the booster swap.
    I know on the older transmission it was vacuum, but I believe on your newfangled crap it's electric ... I know you said you can feel all four gears, but it sure sounds like OD went away. I'd go checking the wiring around the booster, or down under on the tranny.
    -- A
  3. mudbog42
    mudbog42 1/2 ton status
    Jul 16, 2006
    452
    Florida for now
    Wow
    1700---2400, thats pretty good, I run at about 3000 RPM's:D on the highway with 35's and 4:88's:rolleyes:
    Sorry I couldn't help though:bow:
    but how do you like tranny from bowtie overdrives, I've been looking at them recently
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    sounds like the converter clutch in not enguaging. that is vacuum operated up untill i think 88. you have to move it out of the way if not disconnect it to remove the booster. it probably is not hooked up.
    FYI every "gear" is hydraulic in a 700r4 and 4L60, no vacuum or computer controlls any shift. it does however controll the TCC which sometimes feels like another gear.
  5. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    vacuum, vacuum, vacuum. Check for vacuum leaks.....
    BTW i run 4:56 gears with 36x14.5 and do 3100rpm's on the freeway. dont feel so bad. coarse i get 7 mpg too. alot of it is the TH350 though
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    X2 , and my year has the same setup , right next to the booster on engine side of booster .
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Check your shift linkage. Maby when you pulled the booster you moved something or bent something. From your description it sounds like you are in D not overdrive [D]. If you are in drive (3rd) it will shift to 3rd gear and then the TC will lock up making it feel like a shift into 4th.
    Also check the TV cable adjustment. maby you knocked it out of adjustment when you changed the booster.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    interesting...
    with that RPM spread...
    2400 divided by 1700... that's .7
    your OD ratio is .7:1.
    coincidence?
  9. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The rpm difference is too big for it to just be the TCC not locking up. Locked to unlock the TCC should only make maybe 100-200 rpm difference, not 700 rpm. As already mentioned you are probably feeling the trans shift 1-2-3 and then the 4th thing you feel is the TCC locking in.......the trans is never shifting into OD.
