k30 breaks going out........
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84CUCV, May 16, 2004.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Pit in fliud. Good pedel for a short time and then the they right back down to the floor. Cant finf any wet or leacking spots anyware. What else could it be?
    thanks mike
  2. Ben
    Ben Registered Member
    May 3, 2002
    96
    Pick a country in SE ASIA!
    Get on the ground and look behind each wheel... look for signs of a leaking brake wheel cylinder or brake caliper. If none, it's the master cylinder that needs replacing.
    If you are having to add brake fluid, you have a leak somewhere.
  3. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    if theres no leaks it has to be a bad master cylnder /forums/images/graemlins/waytogo.gif
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    looked all aver the truck and didnt find a leaks. Will check one more time. So looks like my master cylnder is shot. how do they go? thanks mike
  5. trikstark5
    trikstark5 1/2 ton status
    Feb 17, 2004
    169
    usa
    Check to see if there are bubbles appearing in the master cylinder while you are applying the brakes. It could be a bad power booster. I just had the same problem and it ended up being a power booster. Good Luck!!!!
  6. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    if it were the brake booster, the brake pedal would be harder than hell to even push at all. Usually worse than manual brakes.
  7. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    There has to be a leak somewhere. Where else would the fluid go? /forums/images/graemlins/dunno.gif ... It doesn't evaporate too well. /forums/images/graemlins/doah.gif
  8. Ben
    May 3, 2002
    96
    If the master is leaking, the fluid would be seeping out between the MC and the brake booster and or into the brake booster. Unless the proportioning valve is leaking....
    but I'm willing to bet your life that the master cylinder is leaking!
    Just replace it and be done with it and on the road again!
  9. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Will see how it goes. thanks
