K30 GM 14 bold ff
Discussion in 'The Garage' started by the general, Feb 18, 2007.
  1. the general
    the general Registered Member
    Oct 2, 2004
    96
    prinsenbeek(the Netherlands)
    My question is :is an 14 bold GM FF rearaxle from a G30 (van) the same as the rear of a k30 and if not what is different than?:confused:
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    It is the same except it's 3 inches wider making it the same width as the front axle. Pretty sure you'll have to move the spring perches and shock mounts, but other than that no difference.
  3. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    I believe the spring perches are placed different. The shock mounts could be different as well.
  4. the general
    Oct 2, 2004
    96
    wow!!!! this is quikservice guys!!! another question: is there a ARB locker for a 4.88 difratio for this axle??? again thanks for the replies
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    :haha: :haha:
    Yes there is an ARB for that axle. If they only make a 4.10 and down ARB then get a thick set of 4.88s.
    Ira
  7. REDCRO_REDNECK
    REDCRO_REDNECK 1/2 ton status
    Apr 7, 2005
    241
    mo
    the van axle is what I am using in my rig.
    the axle is the same width as a dana 60 front, the shock mounts are in the right place, the only difference is the spring perches. I am putting new perches on my axle and will not have to remove the factory ones to do that.
    if you can weld new perches use it, if not just get the right axle
