k30 Shortbed?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SS66, Feb 12, 2004.
  1. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    I dont think so, but might as well ask. Was there ever a K30 Shortbed made?
  2. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    I don't think so
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'm making one this saturday. /forums/images/graemlins/thumb.gif
  4. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    Hmmm, well.. were the frames for the 3/4 tons and 1 tons the same? ( strength wise not length ) Again I dont 'think' so but need confirmation
  5. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    the sister of my boss has a K30 standard cab shortbed dually w/ 454
    as far as i can tell it is stock
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    my 1/2 ton and my 3/4 frame are identicle. the 1 tons were taller under the box /forums/images/graemlins/waytogo.gif
  7. SS66
    SS66 1/2 ton status
    Feb 13, 2003
    538
    WI, USA
    Hmmmmmmm, Ok guys thanks
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    yeah, what he said. cant wait!
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    No, never made.
    Crew cab short beds are somewhat a very, very rare thing if they were ever made, but not to my knowledge.
    K30's were mainly long beds and c&c trucks.
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    [quoteCrew cab short beds are somewhat a very, very rare thing if they were ever made, but not to my knowledge.
    GM never produced a short bed crew cab pickup until the '99+ body style debuted.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That is not true. I have seen and know for a fact that GM produced 88-98s this way. Maybe only from 96-99 or so, but they WERE produced.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
  13. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Taller under the cab also.
    My ex-logging crewcab is a SWB but its not factory. I'm sure a logging co. would have ordered the SWB if it was at all possible, instead of ordering it C&C and having it shortened.
  14. thatK30guy
    Jan 12, 2001
    32,076
    55
    Keep in mind that since the 1 ton frames are "taller", that does not mean the truck will sit "taller." The frames are "taller" going downward on the frame height rather than upwards. /forums/images/graemlins/waytogo.gif
  15. u2slow
    May 9, 2001
    2,217
    BC Canada
    Yup. Which translates into better fuel tank and t-case protection
  16. thatK30guy
    Jan 12, 2001
    32,076
    55
    Plus more weight added to the overall truck, which can or can not be a bad thing. Bad for gas mileage and good for pulling power. /forums/images/graemlins/thinking.gif
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd take another 1000 lbs if it'd seriously stiffen the frame anyday. Hell if I could go back in time and engineer these trucks, I'd run some kind of tube inside the A and B pillars so you couldn't see it and tie it into the frame to keep it more rigid. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  18. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    frame are light though, i stripepd a frame down bare once a longbed oen and it onmly weighs 200lbs, so... but then it was a '68 long wheelbase 2wd frame so give or take up to 50lbs for later frames and for wheelbase differences, but i highly doubt there can be even 50lbs difference
    definitely no k30 shortbeds at least in 70s 80s, and no k30 at all til 77
    i know of a 76 C20 that is shortbed wheelbase 131.5" and frame is not cut or welded anywhere and it is stock original beater rusty shape untouched, no one can explain it, it does have a utility box mounted on it instead of a pickup bed, it is stock down to the common original aluminum black yellow bowtie dog dogdish hubcaps and stock painted white steel wheels and stock size tires
  19. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    [/ QUOTE ] it isnt a short wheelbase C20, no such thing existed. you mention a 131.5" wheelbase, that's not a short wheelbase, that's a standard cab longbed wheelbase, nothing special there. short wheelbase is 116.5"
  20. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Hmmm, I took a bare frame from an '88 K5 to the recycler last fall and they weighed it at 380 lbs. It was just the frame rails, crossmembers, and the factory sway bar. Everything else had been removed.
