K30 sits high?
Discussion in 'The Garage' started by Confedneck79K30, Feb 6, 2007.
  1. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    so after getting the cab on and the tires all aired up... i think this thing sits awfully high, for a stock truck anyways, when i install my 4" lift springs from a k10, will i actually get 4" of lift, or less because its a one ton??
    those are stock size 2005 chevy 2500 tires... 265 70 16s or whatever...
  2. 87'k5boggin
    87'k5boggin Registered Member
    Dec 9, 2006
    76
    pascagoula,mississippi
    tires look small?
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    they will typicaly sit higher do to stiffer/ thicker springs. youll prolly only see 3" of lift...roughly
  4. Steve GMC
    Steve GMC 1/2 ton status
    Dec 3, 2005
    247
    middletown,Connecticut
    ya our k30 sits very for stock, if it didnt have the running boards it would be hard to get into.well not hard but tougher than my stock k10 its a work truck and DD so my dad dosent want to have to climb into it everyday
  5. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    294
    Truckee, CA
    stock tires are 245/75 16's, unless those are different
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    My K30 crew cab sits a lot lower.
    It almost appears to have a small body lift to me, the frame seems to sit fairly low, but may just be my eyes. I see negative arch springs, so that appears stock.
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Is there a motor and trans in the truck?:wink1:
  8. 79k20350
    Nov 22, 2004
    7,757
    Ct
    you can see the motor, i dont know aboot trans...
  9. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I think most K30's have 3 leafs in the front packs, unlike the 2 in 1/2 and 3/4 ton's.
  10. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Most, if not all 3/4 tons are 3 leaf and 3 leafs were an option on k5's/ half tons
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    Is that a true one ton frame?
  12. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    yassir, its a 79 1 ton 4x4 truck
    350/465/205... no body lift...
    definately needs new body mount bushings though... 3 leaf front springs
  13. thatK30guy
    Jan 12, 2001
    32,076
    55
    I've had several Rancho 4" soft ride springs part number 86206 where they list them as 4" to the K5, 10 and 20.
    Rancho lists the exact same spring on their website and catalogs to lift the K30 "only" 2.5".
    I've had these springs on a K10 and 30 before and Rancho wasn't lying. The K10 did go up considerably more than the K30 did.
  14. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    My 3/4 GMC had 2 leafs in the front packs as my K5 does.:o
  15. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    well then, the 4" springs i have are gonna need a zero rate to get me up enough for 38s...
  16. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    mebbe its the lack of inner fenders that make it appear to be higher? the hd wheels and tires were taller side by side than the dually fronts i pulled off, btw...
  17. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    It does look like it sits a little high, but your springs are probably just in good shape. That and your tire is slightly turned so it might give even more of an illusion that its taller thatn it is. :dunno: Besides, isnt that the goal of about 99 percent of people here? Jack the truck in the air. (but not too high otherwise you look gay) :D
  18. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    x2
    my 1/2 ton came with 3 (instructions for snow plow on dash, so that could be why)
    my 3/4 ton came with 2
    my 1 ton came with 3
    my other 3/4 ton came with 3
    next door neighbor's blazer came with 2
    Who knows, depends on the build location and use/equipment.
  19. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    My 83 3/4 with 2 had a diesel from the factory, talk about saggin.
  20. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Now that I think about it my blazer had 2 leafs and the dually crew had 3.:dunno:
