K30 turning radius sucks!
Discussion in 'The Garage' started by ajbirken, Sep 10, 2006.
  1. ajbirken
    ajbirken Registered Member
    Nov 5, 2003
    27
    I have an 84 M1008 CUCV with a 4" lift, a 3" raised steering block with the stock steering arm and 36's otherwise stock.
    I have a decent turning radius when turning left and it is a LOT worse (I can barely park in a normal space if I have to turn right). I have taken the steering stops out completely so they are not the problem.
    I have several other trucks (J10, J20, W250) with the exact same wheelbase of 131" and they kill this thing in turning including the dodge which has a similar style steering (ie draglink to driverside).
    Will crossover fix this? or are there any other adjustments I can make (re-index the pitman arm?)?
    Thanks in advance,
    adam
  2. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    sounds to me like your steering may not be centered.
  3. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Don't feel bad. My 88 F250 HD 4X4 cant do a 360 on a 50' wide street!!!!!:doah:
  4. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    this is common after a lift, you need to adjust the steering to center it, or you could switch over to cross over and it would be even better
  5. ajbirken
    Nov 5, 2003
    27
    Thanks for the replies.
    I have never re-centered the steering.
    Is it something like this?
    1. Do I put the wheels straight
    2. disconnect the draglink from the steering arm
    3. "Center" the steering wheel ie halfway in between lock to lock
    4. re-connect the draglink
    any other input is appreciated
  6. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    First thing I would do is this: Center the wheels, then count turns to full lock left. Then back to center, count turns to full lock right. That will tell you how much if any, you are off. Someone correct me if I am wrong, but I believe you have to pull the pit man arm to correct this.
  7. diesel4me
    Jul 24, 2003
    17,540
    926
    Massachussetts
    huh?...
    I thought the pitman arm was "keyed" with the bolt that passes thru it and clamps it to the splined shaft,so it would not be possible to move the pitman arm on the shaft from its "normal" position?...(on a 4x4 stock steering box anyway)..:confused:
    I'd say it would require removing the "rag" joint at the steering colum,and then center the box,re-connect the rag joint..only thing is,the thru bolt there is "keyed" there too,it only lets it bolt up one way!..
  8. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,601
    551
    Wasilla AK,
    get the tires pointing straight ,disconnect the draglink , put steering wheel in "center" between lock to lock,lock steering wheel , adjust tie rod to meet the pitman arm, reconnect draglink, Done :D
  9. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    the rag joint can only go on 2 ways 180 degrees off
    you need to adjust your drag link so your steering wheel is centered when you tires are pointed strait
  10. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    Don't disconnect anything. Just get the wheels straight, leave the key in the ignition so the steering wheel can turn, and loosen the clamps on the draglink. Then you can twist the adjusting sleeve untill the wheel is centered.
    Now I believe the J10 and J20 are jeep trucks that come stock with crossover steering, not sure on the W250 [dodge maybe?] Did they also have 36" tires? That can affect turning radius too. That may explain why they turn better.
  11. ajbirken
    Nov 5, 2003
    27
    Good ideas.
    The Jeep pickups have X-over stock. The Dodge has a similar setup to the K30. Two of them run 33's the other is stock. FWIW the K30 had this problems before the 36's (like 32's) so I am pretty sure it's a draglink/centering issue.
  12. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    fatbob is correct. you need to adjust the draglink. once you get it turning evenly both ways the only other way to gain steering ability is to get a set of rims that puts the centerline of your tire in line with your balljoints. the farther you push your tires out the larger your turning radius becomes. right now your problem is in the draglink.
  13. ajbirken
    Nov 5, 2003
    27
    Just wanted to give a quick update.
    I followed fatbob's advice and now I can finally turn right! I did not disconnect a thing. Just loosened the clamps and turned the adjusting sleeve and now it's money!
    thanks,
