K30 Van 14bolt FF ratios?
Discussion in 'The Garage' started by BlitzK5, Nov 14, 2005.
  1. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    Anyone know what gear ratio's come in these things? A local junkyard just towed in a 1ton van and I was thinking about heading out there to scoop up the 14bolt.
  2. sweetk30
    Nov 1, 2004
    25,529
    527
    horseheads , ny 14845
    i have a 93 unit with 4.10 and open carrier.
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Is the van 14bff the same width as the truck 14bff?
  4. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Mine came out of a 78 G30 van and it has 3.73's in there now..
  5. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    The van version is 70" wide versus 67" for 3/4 and one ton.
    Rene
  6. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    the van 14ff i got had 3.75 gears :crazy:
  7. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Yes.....Be forewarned... The vans have ratios that you aren't used to seeing on "normal" 1-Ton axles.
    The one I bought had a strange ratio (like 3.75) also, though I can't remember now what it was. :thinking:
    It's posted here somewhere (quick search oughta find it) along with a table of ratios that are in the van-width axles.
    Other than that, the van axles are good for about 3" extra width overall and keeps you from needing wheel spacers to get the wheel track to match the D60 up front!!! :wink1:
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i need one of those
    the bread trucks had them to
  9. sebban
    sebban Registered Member
    Jan 18, 2005
    63
    sweden
    I measured my axles yesturday, the 14bolt was 67" but to my surprise the 12bolt was only something like 64"??
    I have used a 1,5" spacer on the 12 bolt(1,5+1,5+64=67"), and I was expecting the 14bff to have the same width, but apparently not.
    My plan was to use a 1,5" spacer on that one also (want to do the 8 to 6 lug conversion.. )
    but now I guess I can't.. ?? It's going to look ridiculous..
    So now my dilemma is that I can't use my 6 lug MT wheels in the rear, and when I looked at 15" with 8*6,5, I found a few thanks to you guys here, but no matching set or combination with 6*5,5 bolt pattern. The problem is that I still have my 10bolt up front and I want to have matching wheels.
    Any body have any suggestions? (plz don´t tell me to find a D60 or going 8 lug up front.. it´s too much $$$ here in sweden)
    Thanks // Sebastian
    (edited for bolt pattern)
  10. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    you need to look for 8 on 6.5 not 170.
  11. sebban
    Jan 18, 2005
    63
    sweden
