K30 vs K20 vs K10 vs K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Leadfoot, Jun 26, 2001.
  1. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Were all the frames for these 73 - 87ish all the same. I know the Blazers had a different frame in the rear than the pickups, but the front was identical or pretty close. Were all the rears the same for every year blazer? Were the rears the same for every year truck? I know the K30 used different rear spring hangers and longer springs, but were the frames the same as the K20 and K10 (excluding duallies)?
    If you didn't built it yourself, how can you call it yours.......?
  2. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I believe the k10's and k20's use the same frames, but I think the k30 uses a different frame, a bit narrower and made of thicker rails. The higher gvw trucks (some 3/4 tons and of course 1 tons) are the trucks with the 56'' rear springs, but I don't know if thier frames were modified in any way or if it was just the spring hangers that were moved compared to the 1/2 and light 3/4 tons.
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Someone told me they are all the same. Correct me if they are wrong.
    Someone told me they all are different. Correct me if they are wrong.
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The 1-ton frames are narrower in the rear (i.e. the springs are closer together, meaning the spring mounts on a 1-ton axle are closer together than a 3/4 or 1/2 ton rear axle). I would guess the 1-ton frames were thicker, but I'm not sure. I also believe that most, if not all of the mounts, from the cab forward are the same, meaning items such as the front spring mounts, steering box, cab mounts, engine mounts, etc. since all of these parts seem interchangeable between different models.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Some 1/2 tons used 56" rear springs too. My truck doesn't have them but my friend's "heavy half" Big 10 has them, and so do some other trucks even if they're not designated as HD 1/2 tons.
    Tim
  6. Leadfoot
    Nov 28, 2000
    3,112
    Are the spring perches narrower on the 1 ton because of the frame or is it due to the different spring hangers? I don't know, I'm just asking. Also for those that have true 1 tons. Do you have an indentation on the frame near where the factory metal shock boot would be (only in the rear)? I know on the 1/2 and 3/4 tons the frame is indented where the rear shocks mount.
    Also, just to settle curiousity, would someone with a 1 ton take a couple of measurements on the width of the rear frame rail (outside edge to outside edge) near the t-case, over the spring perches/axle, and just forward of the bumper mounting plates. I will measure my 3/4 ton, my buddy's 1/2 ton, and his father's K5 to compare. Thanks.
  7. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    I can't say for sure, but I believe the 1-ton frame rails at the rear are actually narrower. If the frames were the same width, I don't think it would be possible to pull the springs in close enough to the frame the make the difference that there is...meaning that the springs are mounted on the outside edge of the frame and would hit the frame rails. The spring hangers, just from a quick walk by, look the same as the 3/4 or 1/2 tons.
  8. Kennedy
    Kennedy Registered Member
    Mar 1, 2000
    90
    Los Angeles, CA
    I'm told that the frame widths are the same (1/2, 3/4, 1-ton), and that it is just the spring hangers that move the springs closer together on the 1-ton as compared to 1/2-ton.
    David
    1982 6.2L K-5
    2000 Silverado 2500
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    If you took a 1/2 and 1 ton frame, and stripped them down to bare, they would look almost identical.
    The 1 ton frame on the rear part is the same width as the 1/2 and 3/4 tons. The spring hangers are the difference. They are closer inboard causing the 'narrow' rear perches.
    The 1 ton frames are in a class of their own. They are thicker, taller, wider, heavier, and of course, stronger.
    The list goes on and on about the frame variations. I would need more time to explain all the differences. [​IMG]
    <font color=red>I m so we Todd did.
    I m sofa king we Todd did.</font color=red>
  10. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Thanks for correcting Executioner. He is always right or wrong.
    Dave
    BEER: It's not just for breakfast anymore.
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    ROTFLMAO!!! [​IMG]
    Yeah, I have Executioner figured out now!
    He's not quite that bad a fellow! Sure he seems a bit 'fruity' sometimes, but I think he means more good than harm. At least you cant blame a guy for trying! [​IMG]
  12. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Wes, the 1-ton frame is the same in the rear except for the hangers...then why couldn'y you bolt on some aftermarket shackles like ORD and use a 3/4 ton 14bolt on a 1-ton frame? I realize that would be work for nothing, but it seems like I have heard the frame is actually different...
    -- Mike
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    How much thicker/heavier is the 1 ton frame?
    Tim
  14. Leadfoot
    Nov 28, 2000
    3,112
    Do I sense a contradiction here Wes [​IMG][​IMG].
    You say the 1/2 and 1 tons stripped, looked the same and are the same WIDTH, but in the next paragraph you say the 1 tons are taller, stronger, WIDER, etc. Wassup wit dat?[​IMG]
    Also do the 1 ton frames have the shock boot indentation like the 1/2 and 3/4 tons? Sorry for all the questions, but I'm a curious SOB.
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    I will reply later today, since I'm at home on lunch right now. This will take some time to explain. [​IMG]
  16. Leadfoot
    Nov 28, 2000
    3,112
    I'm still curious.
    Yeah, yeah, I know, I'm a royal pain in the a$$. But hey if you don't ask questions, you never learn.
    There is no such thing as a stupid question, just stupid people that ask questions........Gee I wonder what that makes me?[​IMG][​IMG]
