K35 front lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by elacruze, Feb 1, 2004.
  1. elacruze
    elacruze 1/2 ton status
    Dec 23, 2003
    121
    SE Michigan
    My '85 K3500 is about two inches higher in the rear than in front;
    http://mywebpages.comcast.net/elacruze/pickup.JPG
    I'd like to get about 2" more in the front springs-what's the easiest way to do this? I was thinking perhaps just add another 3rd leaf to the pack. It's a 2 ton, so it's already too stiff to worry about articulation issues. I know I could use an add-a-leaf, but I'd like to add a bit of travel rather than just height and tire clearance.
    Eric
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    That thing is a great stock heavy truck. They all sit higher in the rear.....until you put some weight in it. Do you still use it as a work truck? If you are I'd have your springs rearched or custom packs made. This will get you lift and still be able to use the truck. If you want travel perhaps you need some softer springs or ar least swaybar disconnects.
  3. elacruze
    Dec 23, 2003
    121
    SE Michigan
    It will see a lot more usage as a recovery/tow vehicle than for play-wheeling. There are plenty of spring shops around to re-arch or custom, but I'm a cheapskate and I worry about anyone who isn't a metallurgist/heat treat specialist making springs which will last. I don't want to soften the front, although swaybar disconnects and longer travel shocks will come to be sure my travel isn't limited but by the springs. I have a 12k Koenig hydraulic winch and custom bumper not shown in the pic which together weigh about 350lbs adding to the front dip.
    Is crossover steering something I should consider with leafs and a 2 or 3" lift?
    Any related information is appreciated.
    Eric
  4. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    My crew cab had stock 3 leaf front sprigs and it sagged also. If it were me, I'd get a set of 2" lift spings for the front and let it fly. Crossover is good but not mandatory, the stock configuration should work just fine assuming the parts are good.
  5. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    2 ton? /forums/images/graemlins/thinking.gif
  6. elacruze
    Dec 23, 2003
    121
    SE Michigan
    Yeah, special order fleet truck. 3900lb camper capacity, 4500f/6084rr GVRW.
  7. BlueBlazer
    Feb 15, 2001
    1,940
    Uh, that doesnt make it a two ton truck. Dana 60 and 14 bolt rear have always been one ton, nothing more. About your original question, I would buy a new set of 2.5" springs instead of rearching or any of that.
  8. elacruze
    Dec 23, 2003
    121
    SE Michigan
    Call it what you like. I know a ton is 2000lbs, and I got three of them in the back.
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    GAWR stands for Gross Axle Weight Rating. That has to do with how much weight your axles can be loaded. It has nothing to do with the overall weight of the truck.
  10. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Exactly.
    Also don't forget when you're looking at that 6k lbs capacity that some (if not all) of the vehicle's weight is also included in the same figure since the axle is already carrying that (in addition to payload).
  11. elacruze
    Dec 23, 2003
    121
    SE Michigan
    OK you hotrods, go out to yours and see how much weight you can put in the bed-that's the camper weight information. Mine is 3197. I guess that makes it a 1.5985 ton. If this is the only point you can find to make yourselves experts on, your A sucks buttermilk. Who TF really cares?
  12. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    No problem, just trying to help. If you go shopping for those lift springs be sure to tell them you weant them for a 2 ton chevy, good luck. /forums/images/graemlins/rolleyes.gif
    BTW - my crew cab has a GVWR of 9200+, is it a 4.5 ton? /forums/images/graemlins/histerical.gif
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The "ton" ratings are from back in the day when a 1/2 ton really only could carry 1000 lbs. Now they can carry much more than that depending on springs so those actual numbers and their meanings are just from long ago.
    Both of my 1 ton's GVWRs are 9,200. Guess I better tell my parts guy I have a 4 ton truck the next time I go in for u joints, so he can give me one the size of a transmission.
  14. BlackDog714
    BlackDog714 1/2 ton status
    Jun 8, 2002
    260
    Indiana
    Actually you are shorting yourself, it's 4.6 ton...
    My truck has a GVWR is 11000, so I have a 5.5 ton K3500. /forums/images/graemlins/eek.gif
  15. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Dude, two things:
    1) It's a 1-ton. stock K30/K35 = 1 ton, no matter what that sticker says (unless you put Rockwells under it or something).
    2) You have 27 posts. I'm not saying post count measures your knowledge of trucks, but coming on here, being relatively new, and then being stubborn about accepting advice as well as calling people names will not earn you brownie points. /forums/images/graemlins/deal.gif
  16. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I like brownies.
  17. thatK30guy
    Jan 12, 2001
    32,076
    55
    Too bad you have to go out with a bang like this. Would have been nice to have another K30/35 member along with myself. If I were you, I would apologize and get on with life. Don't second guess anybody on this site because most of us know what we are talking about. If you seriously doubt us, go to your local GM dealership and personally ask them what GAWR or GVWR stands for. Then when you get the answer, we will be waiting for your apology and accept you into this site as a "regular" even though you have what...27 posts? What a shame. /forums/images/graemlins/frown.gif /forums/images/graemlins/shame.gif
  18. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    no honestly, two one ton axles=2 ton.. dontcha know? /forums/images/graemlins/histerical.gif
  19. thatK30guy
    Jan 12, 2001
    32,076
    55
    So a 5 ton military 6x6 truck would be a 15 ton? /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/histerical.gif
  20. Confedneck
    Nov 1, 2002
    5,236
    of course.. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/doah.gif
