K3500 Brake Problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jackedup86GMC, Nov 12, 2006.
  1. Jackedup86GMC
    Jackedup86GMC Registered Member
    Jul 27, 2006
    64
    Southeast Texas
    Most times my brakes work great. However, sometimes after I have stopped, then started to move again, the pedal is really spongy and I have to pump the brakes 2 or 3 times before the pedal feels normal agian. I have no evidence of fluid loss anywhere on the truck. Is this maybe a vacuum problem related to the power booster? Any ideas?
  2. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    Check the rear wheel cylinders they will let air get in the system also the master cylinder may be leaking to the inside of the booster I have had this happen. The seals in the master my be going bad that sound alot like the seals. Normally what happens is one section of the master will bypass or it is sucking air in the back of the master cylinder I have seen all these happen at the shop. From what you are saying it sounds mostly like a bad master get a rebuilt or new master andd this should solve your problem.
    bigred81
  3. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    pull the master off the booster with the lines still connected, and stick a rolled up piece of paper down towards the bottom of the master and look for signs of wetness on the paper, if there's wetness, you know its leaking into the booster... if not, check the rear wheels for wetness behind the drums...
