K5 AC
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rts, Jul 28, 2001.
  1. rts
    rts Registered Member
    Jul 28, 2001
    15
    Dallas, TX
    I have a 89 K5 blazer. The AC just stopped blowing cold. Should I have it switched off of freon, or just re-charge it? How much should it cost to make the change?
  2. Haulgas
    Haulgas 1/2 ton status
    Mar 25, 2001
    208
    Phoenix Az
    Where Are You?
    IT'S NOT JUST A J**P THING AND I DO UNDERSTAND
  3. rts
    Jul 28, 2001
    15
    Dallas, TX
    Dallas.
  4. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    Ask someone who does AC work to try to recharge it with Freeze12 refrigerant. I put it in my 89 C1500 and it does great!...NH K5
    Neil H.. Alabama.. '78 K5 400ci 4x4 AT,AC,PW Cheyenne. '74 C10 3spd/floor 250ci 4x2
  5. Bowtied
    Bowtied Registered Member
    May 21, 2001
    69
    NC
    From what I was told by a mechanic, the r12 cools way better than the new stuff (134 I think).
    I just did mine tonight with the r12 and it feels goooood!
    Hope that helps,
    Bowtied
  6. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I have an 89 Jimmy and live in McKinney......just did the air thing since my compressor went tits up.....my only leak was at the Schrader valve on the Accumulator (silver can with hoses near the firewall).....that part was about $10, and cleared up my leak (very common leak point)...I had the system charged with Freeze 12 and dye, so I ran it for a couple weeks to see if there were any more leaks.....my compressor was making a lot of noise, but cooling just fine....since there were no more leaks, I went ahead and changed out the compressor for a New one...at that time I also replaced the Freeze 12 with Freon....total cost for New Delco compressor, Freon and labor was $680....the Freon accounted for $182 of the total.....the Freeze 12 was working OK, but I learned in here that it would eat rubber parts or something and since I plan to own this truck forever, I opted to go with all new parts (usually winds up being cheaper in the long run).....I now have Very cold air....recommendation from a good friend (and a little price shopping) landed me at Jay's Auto Supply on Parker in Plano....972-424-4596.....sorta long story, but he treated me right (my friend used to work there)......the cost for finding the leak, replacing the sending unit, and charging with Freeze 12 was about $80, but like I said, my leak was just the sending unit....you may want to give him a shout and see what he can do for you.....I feel that he treated me straight......hope your problem is as simple as mine was....(minus the compressor).....it gets purty dang warm here come late July and August.......JD
    Stuck?...Hell no..I still got some gas left..
  7. rts
    Jul 28, 2001
    15
    Dallas, TX
    Thanks for the info.
    -Ryan
