K5 Blazer mirrors
Discussion in 'The Garage' started by jfleming, Jan 25, 2006.
  1. jfleming
    jfleming Newbie
    Aug 24, 2005
    Oxford, MI
    Does anyone know how to adjust the K5 blazer mirrors so that when you shut the door the mirrors dont loose the adjustment? Usually you have to fight the opposite.....they normally rust in place and you cant adjut them...
    thanks in advance
    Justin
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    On the bottom of the mirror mount cover there is a torx screw. Remove it and the cover will slide upwards. You will then see the tensioning bolts. They are teh two in the middle. When you tighten them they put more clamping force on the mirror shaft.
  3. rwright07
    rwright07 1/2 ton status
    Jul 30, 2005
    536
    corporate hobo
    will that work on a '76 as well?
  4. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    On a 76? I am guessing you have the small mirrors. If so, there's no way of tightening them that I know of. I have the same problem, unless you mean the mirror is loose on the mount instead of the ball pivot. Then you just have to take the mirro off with the phillips head screw, and bend the tab, i think forward, hook the tab in the mirror and tighten the screw tight. If it's the ball pivot loose then I think it's time to get new ones. On my 76 I gave up, don't wanna spend the extra $35 for mirrors from LMC.
    If they are the bigger mirrors with a tripod mount, I am unsure, I have never really heard of them getting loose. Someone may chime in with some info.
  5. rwright07
    Jul 30, 2005
    536
    corporate hobo
    i think they are aftermarket, they have the trangle shape base part and the large rectangular mirrors.
