K5 driveshaft question
Discussion in 'The Garage' started by KevinsK5, Oct 12, 2005.
  1. KevinsK5
    KevinsK5 1/2 ton status Premium Member
    Jan 17, 2005
    257
    13
    Golden, CO
    Hi I'm trying to buy two Blazers (one a 73 the other a 78) and I have a question regarding driveshafts. Both driveshafts are gone out of the 73, but the 78 has both. The 73 has a dana 44 front, and the 78 has a 10-bolt. Will the front shaft from the 78 swap right into the 73 without changing U-joints? How about the rear? Both are autos with 203 T-cases, and neither of them are lifted. Thanks, Kevin
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    Not sure on that one, probably not. wait till some of the real experienced guys chime in.
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Yep should bolt right in!
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    May not fit , depends on whether both cases have the same output . In the late 70's GM went from a spicer style shaft with a strap on the u-joints up front , to the square flange with the 4 bolts . I have on of each 203 here , and I am talking about the front output shaft .
    Just checked my LMC catalogue , and both are listed for the cutoff year of 1977 , so you need to look .
  5. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Crawl underneath and if both look like they will fit then they will. If you see omething obviously different then they wont. Im betting they will tho.
